Question about Olympus Cameras
Olympus Stylus 1030SW. The LCD monitor is pixelated. The pictures that are taken with the camera are crisp and perfect. When reviewed on the camera, they are very pixelated. When searching through menus, there are lines going across the screen. Was wondering if there is a way to reset the monitor or if this is a repair that needs to be done by the manufacture
    President:
  • 919 Answers
You can try to reset the camera to factory defaults to see if this improves the monitor. You go to Menu and then left arrow to Reset and press Ok. Up arrow to Yes and Press ok this will put the camera back in factory default settings. If the screen still shows as pixelated, you might try to do a function of the camera called Pixel Mapping. Go to Menu and then right arrow to Setup then down arrow to Pixel Mapping - right arrow to Start and then the camera will try to repair the CCD processing chip inside the camera. If after this completes if the screen is still pixelated, then you want to send it to an Olympus service center for repair.
Posted on Dec 17, 2008
My Olympus x-42 doesn't take a picture. View from monitor is perfect but when I take a picture, all there is is a white screen
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value.
Click on or copy and paste the link into your browser... CCD Sensor Problems
In this link, other owners with this problem obtain certain commets:support/canon_fs100_fully
Hope this helps.
Aug 15, 2012 | Olympus X-42 Digital Camera
My Olympus 1030sw is 8 months old and I took it
Well, getting it wet voided your warranty. Remove the battery and card...don't try to turn it on to avoid short circuits.You can try to bury it in some dry, uncooked rice for a couple of days. Water , especially salt water, is disastrous to cameras. The chance of it working are slim and even if it does for awhile, it may stop altogether later. Keep your fingers crossed.
Nov 26, 2009 | Olympus ? 1030SW Digital Camera
Pixelated Pictures/washed out
In the setup menu, look for an entry marked "reset". if you find it, it can return your camera to the original settings.
Aug 13, 2009 | Olympus Stylus 1010 Digital Camera
Pixel problem, all pictures taken have poor pixel resolution
It sounds like you set the file settings to a small file size - perhaps in order to get more photos on a single memory card. You need to change the setting to the largest file size possible, at the highest quality. The steps for this will be in your manual. If you need detailed instructions and don't have your manual, let me know and I'll lookup your manual online.
Dec 30, 2008 | Olympus Stylus 600 Digital Camera
Write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Sep 26, 2008 | Olympus Stylus 710 Digital Camera
Black spot on pictures, and lcd viewing
Hey cj17,
Since this spot is both on your lcd and your pictures the lcd is most likely not to blame. This spot is probably caused either by dirt on the lens or the sensor, or it could be caused by a dead pixels on the sensor. You can try cleaning the lens, and if this doesn't work you should have it looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 28, 2008 | Olympus Stylus 720 SW Digital Camera
How to view
There are two ways to view the photos, in the camera...
1) if the camera is OFF and the lens barrier is closed, just press the Play (>) button once to view the photos.
2) If the camera is in SHOOTING mode with the lens barrier open, press the Quick View button twice in rapid succession.
When you are done reviewing the pictures, press the Quick View button once to turn the monitor off, OR, to return to the shooting mode, press the shutter button halfway.
Then use the arrow pads to go forward and backward.
Hope this helps.
Nov 24, 2007 | Olympus Camedia Stylus 300 Digital Camera
Review the pictures
Press the QUICK VIEW button. The last picture taken is displayed. Use the arrow pad to display other pictures. Press the QUICK VIEW button again when you are ready to take another picture. Using the Mode Dial Turn the mode dial to the playback option (the green arrow). Use the arrow pad to navigate to your picture of choice.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Cameras Logo
181 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
