Question about RCA F27442 27" TV
Xbox how do you connect an xbox to the rca f27442?
    Sergeant:
  • 241 Answers
Hi there are you using the XBOX 1st or the 360
The supplied cable that comes with the xbox is a RCA and Should have a S-Video too
Just connect and make sure that the TV is set to VIDEO 1
That is were you wil connect you XBOX
was the FixYa Expert Helpful Rate Kindofcheap
Posted on Aug 30, 2008
RCA F27442 - Cable showing up "snowy". Found tv outside, so maybe it's shot, but wanna chk just in case. Anything other than what 'Menu' offers can help - something physically inside...
Real common problem with RCA, bad connections in tuner/ if module, Solder tuner and if module and leave shield off tuner and solder main grounds around tuner.
Aug 15, 2011 | RCA F27442 27" TV
No sound or video,only a crackling noise.rca 27 inch entertainment series tv model# f27442 chassis# ctc203ad5
Problem in the high voltage circuit, check connections on flyback transformer and high voltage diodes on flyback to see if shorted,
Apr 25, 2011 | RCA F27442 27" TV
F27442 - How to display signal from front panel RCA video input
To display signal from that input you will need to change the input on the tv. This can be done either on the front of the tv, or by using your remote control. First power on and connect the desired source. Next on the tv or on your remote, press a button labeled either source or tv /video and scroll through by continuously pressing until you see the source you connected appear on the tv display.
Good Luck
Jan 07, 2011 | RCA F27442 27" TV
Need a user manual rca f27442
If you can't locate a free version, you can buy from here: http://online-owners-manual.com/f27442.html
Nov 09, 2010 | RCA F27442 27" TV
No picture but have sound. RCA Model F27442
you have the problem in the heater try to resolder the parts in the crt socket the one that is connected in your picture tube if nothing happens check the resistor if open replace it common value is 5.6ohms.
Oct 14, 2010 | RCA F27442 27" TV
I have a rca f27442 tv and the picture is half
yes!!!! very common problem. soldering the vertical section and the grounds around the tuner section will fix it. guaranteed fix. for a quick fix, take off back and while tv is on, take the plastic side of screwdriver and tap tap tap the tuner section. see i told you that would fix it.
Nov 10, 2009 | RCA F27442 27" TV
I have an RCA F27442. I get a popping sound and
You have a bad flybacktransformer. This is what is causing the popping!
Aug 10, 2009 | RCA F27442 27" TV
RCA Model F27442 has sound but no picture
check to see if you have B+ to the horz.output transistor.
also you may have bad solder connections on the countdown osc. ceramic resonator.
Dec 24, 2007 | RCA F27442 27" TV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
RCA F27442 27" TV Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
