Question about HP Pavilion ze4300 Notebook
Pxe e61 media test failure check cable
LAPTO WONT LET ME IN
  • 2 more comments
  • KOBEGUST Aug 30, 2008
    ur dumbb
  • lavetsosie74 Nov 17, 2008
    media test failure, check cable : operating system not found
  • Anonymous Jan 14, 2009
    same problem, same error note. Now won't boot at all. Didn't even get a chance to try rearranging the bios. Help!
  • cro7690 Feb 06, 2009
    Needed to take my lap top apart to replace the power connecter board. When I turned the computer back on I got the message pxe e61 can anyone help me?
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: GETTING ON MY LAPTP: PXE-E61: Media test failure, check cable
This error message can be caused by a faulty connection to the hard drive or a faulty hard drive or a faulty disk controller.
Go into the BIOS configuration to see if it has detected the hard drive, if it is not detected that is why the laptop won't bootup.
To confirm or check if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port (you may need assistance from a computer savy friend).
If this computer cannot see this as an external drive then it is faulty. If the computer can see this drive as an external drive and you can open the folders and files on the hard disk then the hard drive is OK and the fault is probably a faulty disk controller on the laptop. A faulty disk controller is part of the motherboard and the only fix is a replacement motherboard. This may not be a cost effective solution and it may be better to put your money towards a new laptop.
Posted on Jun 28, 2009
Geekman
  • 32281 Answers
SOURCE: pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Posted on Sep 23, 2012
Computer wont boot error code pxe e61
You must initialize the new hard drive first.
Jan 28, 2014 | Toshiba Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
HP Pavilion ze4300 Notebook Logo
479 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
