Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Belt constantly snapping
After replacing belt and turning on, belt snaps in 15 seconds. Agitator turning. Any ideas on why this is breaking?
Make certain the belt is twisted the correct direction and that the brush is free to rotate. If the belt is twisted the wrong way it will probably come off or breake
Posted on Aug 30, 2008
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
1. Place handle in operating position and turn cleaner over.
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
Put new belt on and the wheels are to high in the front of sweeper
Is this a dirt devil. First and foremost these things ****! secondly the wheels have to be snapped in underneath the piece that covers the belt. even when that is done the wheels will force the vacuum to low and stress the belt so much that it breaks! See my other suggestion on how to remedy this!
Sep 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
How do I replace the belt in my hoover empower
There's a plastic cover over the agitator. (the part that should spin, with tough bristles)
Unscrew it. Pull out the agitator. Put the new belt over the 'spinner' (the part that's connected to the motor) and the special pafrt of the agitator. Snap the agitator back into place, making sure it's secure on both sides.
Screw back on the plastic cover.
Wallah!
Apr 25, 2008 | Vacuums
My belt broke. I have a replacement. I dont know how to install the replacement belt.
Wallah!
Panasonic MC-V7395 Belt overheating/snapping
I have the same problem. I keep thinking I have fixed it, but then another belt breaks. I only have the issue when the roller is disengaged. (on bare floor setting). I did find that the unit was slipping back into engaged slowly, because the disengage mechanizim was not kathing prperly,. Tightened up a screw, and now appears to hold, but somehow the belt still get broken - I beleave it is an issue that the belt is not staying away from the drive when it is disengaged.
Jan 05, 2008 | Panasonic MC-V7395 Vacuum
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
156 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
