Question about Palm Treo 650 Handheld
Retrieving Back-up contacts/phone book
Which data file contains contact/phine book. I lost my contacts data from my TREO 650. I had previously made a back-up of my Palm Desktop data by saving all of my data to another folder. I want to use the old data - only for my contacts/phone - How do I retrieve the old data next time I hot synch
    Master:
  • 473 Answers
Try Desktop overwrite HH. I've lost everything on my HH a couple of times and had to set the conduits to 'Desktop overwrites HH' in the hotsync manager - Custom settings for the next hot sync. If what you have on desktop isn't what you want, you should copy your saved folder info back over whats in your palm folders (i.e) where you copied it from.. Before you complete this step. Then your old data will be copied to your HH. Note - I assume you "copied" , not "archived" the data.
Posted on Sep 11, 2005
Sync calendar to microsoft exchange server
Update your Versamail version to 3.5.4
Also, make sure that sync calendar and contacts is checked in the settings on your Treo.
Good Luck!
May 21, 2009 | Palm Treo 650 Smartphone
How do I export contacts from a Palm 650?
First thing what is your new phone you using now?
If still the same palm operating system,what you need to do is just 1.export your contact from your palm desktop.After that you create a new ac for your palm desktop then import the file you export just now to the palm desktop again.If you are using windows mobile repeat the number 1.then go to your active sync user ac and import from the file you export just now.
Dec 28, 2008 | Palm Treo 650 Handheld
Palm treo 650 wont get service
If the phone is new to you, (different story if it was working on cingular before .. let me know if it was)
It sounds like it is sim locked, the phone needs unlocking.
If you can contact the previous owner and ask them what network it was on and borrow a sim card from that network it will verify the phone isn't faulty or blocked
The previous owner may be able to get it unlocked for you via there provider else somewhere like www.650unlock.com will do it for about $15 (I'm not recommending them, just one of the first in a search) Its worth googleing "treo 650 unlock" and shopping around also check 650 forums for recommendations
Best of luck
Jun 08, 2008 | Palm Treo 650 Handheld
Help please
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
Resetting to Power Off
hi dear
Good luck
cropp
Mar 07, 2008 | Palm Treo 650 Handheld
Outlook Calendar synchronization failed in palm treo 650
hi dear
Good luck
cropp
Feb 24, 2008 | Palm Treo 650 Handheld
Unable to place a call or receive a call on treo 650
May I know since when the problem occur and what's happen if you tap phone application?
Nov 07, 2007 | Palm Treo 650 Handheld
Treo 650..In contacts, how do I delete many at a time instead of one at a time
I suggest that you create an additional subfolder under your main contacts for your master contact list and use the main contacts file as your list for syncing with your treo. Once you have your contacts moved around you need to change your setting on the sync to have your pc override the handheld. I use pocket mirror to sync with and it's a fairly simple setting to change. I would also suggest that you export your contacts to a back up .pst file before doing the sync. If it messes up on you with duplicates or something you can alwaws just delete the contacts and import them from your back up. I recently cleaned up my duplicates on a treo 600 using this method.
Sep 12, 2005 | Palm Treo 650 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Sep 11, 2005 | Palm Treo 650 Handheld
Deleting Outlook contacts
FileZ file utility lets you delete the AddressDB on your Treo Your best bet would probably be to wipe the Contacts database on your Treo 650, then re-sync. 1. Install FileZ on your Treo 650, Why? Because the Contacts DB is not accessible from the built-in system; you need this extra file manager to delete it. 2. Launch FileZ and find this item: AddressDB. 3. Tap on AddressDB to add a checkmark next to it. Hit Details. Hit Delete. 4. DON'T HOTSYNC YET! Just in case, export your Outlook Contacts and store in a safe place. You'll be syncing to a blank address DB on your 650, and although it shouldn't overwrite your Outlook data wwith the blank DB ... better safe than sorry. 5. Now you can HotSync to Outlook.
Palm Treo 650 Handheld Logo
117 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
