Question about Palm Tungsten T3 Handheld
HotSync Manager 6.0.1 and T3
Hi. I've had my T3 for 2 years, no problems. I bought a T5, and installed the newer Palm Desktop, HotSync manager, etc. The new HotSync Manager won't sync with the Outlook Calendar, although all the other Outlook Conduits (Notes, Contacts, Tasks) sync up just fine. Here's my log: Outlook Notes - Fast Sync OK Outlook Notes Outlook Calendar OLERR:0D-000F OLERR:0D-0004 OLERR:0D-0001 - Recovery Sync Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 Outlook Contacts - Fast Sync OK Outlook Contacts Outlook Tasks - Fast Sync OK Outlook Tasks I am using Outlook 2002 SP3. And it worked fine before I installed the T5 Palm CD. So, is HotSync 6.0.1 even supposed to work with a T3? (I really like it, with the log exporting to html and all...) Any ideas?
4 Suggested Answers
SOURCE:
  • 473 Answers
SOURCE: How Do I hotsync w/Outlook
what software did you download for your outlook conduits? the installation cd already has the outlook conduits you need.. you just have to install palm desktop first then you'll be given options whether to sync your handheld with palm desktop or with outlook. choose sync with outlook
Posted on Sep 11, 2005
  • 473 Answers
SOURCE: MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
  • 473 Answers
SOURCE: OLERR messages, however all of mine fail to sync: Calendar, Contacts, Tasks, Notes. Tried web troubleshooter to no avail. Can anyone please shed some light on this issue??? Thanks
I was having the same problem, and I used Detect and Repair in Outlook. Now all is working fine. You will need the original CD that you installed from. Hope this helps as none of the other things that I saw on any sites did until I tried this.
How to add dektop icon for PC to save Palm data
Original disc is probably not compatable with Win 7. Check out
Palm Support Palm Tungsten E2 Palm Desktop 6 2 and HotSync Manager... for newer software that MIGHT work.
Apr 17, 2014 | Palm Z22 Handheld Organizer with Color...
Hotsync
You probably need the latest version of the palm desktop. Here: http://h30434.www3.hp.com/t5/Palm-and-WebOS/Palm-Desktop-6-2-2-download-here/td-p/4720180
Apr 17, 2014 | Palm Zire 31 Handheld
Can't hotsync replacement t5 ; I dropped my working T5 and have not been able to hot sync my backup unit.
If the new one won't pick up your old files you need to go onto the desktop app and export the data. then create a new id on the new palm. It should now hotsync with the new blank id. Now go back to the desktop and import the files from the other id. Hotsync again and you should have them on your palm.
Mar 19, 2010 | Palm Tungsten T5 Handheld
Can not hot sync my unit with windows vista
Palm says that it is not possible, because the software that they have does not work with Vista. However, there is a fix to this! :) For these instructions, you will need the usb cord. If you need to do it via bluetooth, or infrared (IR) or want to read further instructions, visit this link:
http://forums.palm.com/t5/Windows-HotSync/Windows-7-and-Vista-hotsync-instructions-here/td-p/251755
First, you will want to download the Palm desktop 6.2 and hotsync manager here:
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
Then, you'll need to download the Pimlico hotsync software here:
http://www.pimlicosoftware.com/palmhotsyncsetup.exe
Install them both, and you're off!
~Marianne Is-Loved~
Dec 30, 2009 | Handspring Visor Prism Handheld
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
LD and Navman SmartST with Bluetooth ?
You might need to install the NavMan T5 update (not the Palm T5 update!) before it'll work on your LifeDrive. Dunno, but try it without first.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
T5 synco with Outlook except Tasks
Hard rest resolved problem for me. I just posted yesterday a similar problem with my T3. While everything else was syncing fine, the Tasks from Outlook would not sync. After I posted my question, I (accidently) did a hard reset on my T3. So I set all Outlook conduit settings to 'Desktop overwrite HH' for first hotsync. This somehow corrected the problem with the Tasks, and all outlook tasks appeared on my HH. All sync's seem to be working fine now.
Sep 11, 2005 | Palm Tungsten T5 - Multilingual Handheld
3rd Party application failure
First, reinstall the 3rd party conduit and related application. Next, check with the developer of your conduits to see if they have a patch or information on their software and the new Palm Desktop. If the problem persists, try the following: 1. Backup the c:\palm directory 2. Uninstall all 3rd party conduits 3. Uninstall Palm Desktop 4. Re-install Palm Desktop 5. Re-install all 3rd conduits. 6. Synchronize to test.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Synch problem after installation
If your cradle is connected to a serial port, you will need to ensure that HotSync Manager is configured to use Serial Ports. To do this, follow these steps: 1. Click the HotSync Manager icon in the Windows system tray. 2. If there is a check mark next to the 'Local Serial' menu item, then you are already configured. 3. If there is not a check mark, click the 'Local Serial' option. For more information, refer to the handbook that came with your handheld. If you did not uninstall your previous version of Palm Desktop, the configuration will be done automatically.
Palm Tungsten T3 Handheld Logo
279 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
