Question about Canon PIXMA MP600 all-In-One InkJet Printer
Mp600 pixma printer
Paper wont feed, rollers moving at bottom noisy clicks but wont feed. Removed rear cover to check for paper but nothing. Removed paper tray reloaded, same problem.
  • Anonymous Mar 15, 2014
    My printer is not set up as "wireless". The setup disc supplied with it is unreadable and I cannot access the wizard to guide me through changing the default paper-feed to load from rear tray.
  • Anonymous Mar 27, 2014
    wont feed paper
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Posted on Sep 07, 2008
  • NextTimeALaser Mar 23, 2013
    raindncr97, I don't know who you are, but thank you. I've been trying to work out why my auto-print feeder is broken and you're spot on. I had accidentally pressed the manual/auto feed selector button. I didn't even know that button was there or what it did till you pointed it out. The on-screen message is completely inadequate. Thank you.
I will keep raindncr97 in my troubleshooting files. After 1 hour of searching all over the place I decided to read the FixYa! section and, again, his solution solved my problem.
Thanks-a-bunch!
Posted on Nov 11, 2008
    Problem Solver:
Just like raindncr97 states for the cassete error "no paper" I press the feed switch and now my printer works fine thanks raindncr97."verynice solution"
Posted on Sep 19, 2008
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
Feb 07, 2018 | Canon PIXMA Office Equipment & Supplies
HP c5180 printer paper jam error
Please try these general troubleshooting steps for paper jam issue: Turn off your printer to allow the paper feed rollers to turn freely. Remove the rear access door and check the pressure rollers. Verify that they are clean and clean the rollers with a soft towel if needed. Check if there is any jammed paper in this section and remove the jammed paper from the rear access door opening. Make sure that there are no torn pieces of paper in the fuser area and duplexer slot. Check if the carriage moves freely. Use both your hands to remove the paper that is stuck in the roller in order to avoid tearing of the sheet. Discard any paper that is damaged, and then reload the paper into the paper tray. Unlock the print cartridge access door. Check if there is any packaging material or paper debris stuck on the small metal pressure rollers that ride on the main feed roller. Do not mix different types of paper. Load only one type of paper for a print job. Make sure that the paper meets the paper-handling specifications. Slide the paper-length adjuster against the end of the paper stack and do not overfill the input tray. Connect the power cord and turn on your printer. Try to print a sample and if the error persists, then try to reset the printer. Try to update the driver. If nothing works, then service the printer.
123 HP COM Setup Printer Quick Setup and Install Support
Mar 24, 2013 | HP Photosmart C5180 All-In-One InkJet...
Won't feed from bottom tray.
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
If the rear guide is tight, or even snug, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, you will see calibration marks for the paper size you are using. Unlock the rear paper guide, squeeze the release, and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
If you have tried that, you can open the plastic box housing the roller in the tray and remove the lint that accumulates on it. I pry the box open with a small screwdriver.
Apr 01, 2010 | Brother MFC-8860DN All-In-One Laser...
Brother Laserjet 8860dn printer not picking up/feeding paper
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
I have hp officejet 6210 problem with paper not loading
Turn off the HP product and turn it around so the back of the unit faces you.
·Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
·Locate the rear access door and then open it by turning the dial counter-clockwise and then pulling the door toward you.
·Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
Click How to buy on this page to order replacement parts.
·From the rear access door opening, remove the jammed paper. If some of the jammed paper cannot be removed from the rear access opening, carefully remove it from the front of the unit.
·Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
·Reinstall the rear access door.
·Reconnect the power cord to the unit and turn the unit on.
May 29, 2017 | HP OfficeJet 6210 All-In-One InkJet...
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
My paper keeps jamming
Clearing paper jams Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
  1. Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
  2. Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you. NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems. Figure 1: Rear access door c00101861.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
    • If under warranty, contact HP to obtain a replacement part.
    • Click How to buy on this page to order replacement parts.
  3. From the rear access door opening, gently pull the jammed paper free.
  4. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
  5. Reattach the rear access door by inserting the two pins on the right of the door into the holes for them (as shown in Figure 3 below) and then pressing in gently but firmly on the left side. Figure 2: Inserting the rear access door guide pins into the holes c00099183.bmp
  6. Reconnect the power cord to the unit and turn the unit on.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Fax Jam
hp tells me to do the following
does this help you ?
Issue While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur. Clearing paper jams Remove the jammed paper by following the steps below: WARNING: Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
  1. Turn off the HP product and turn it so the back of the all-in-one faces you.
  2. Disconnect the power cord from the back of the all-in-one. CAUTION: The power cord must be disconnected to allow the paper feed rollers to turn freely and avoid mechanical damage.
  3. Locate and open the rear access door by pressing in on the left side tab to release the catches and then pulling the door toward you. Figure 1: Removing the rear access door c00100775.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord and turn on the all-in-one.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
richard from chicago
Dec 02, 2007 | HP Officejet 5510 All-In-One Thermal...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
468 people viewed this question
old marine
old marine
