I had a loud fan problem on my Media Receiver (PDP-R04U) for my Plasma TV. I opened the top of the receiver to see which fan (there are 2) was making the loud wering sound. It wouldn't go on so I put everything back together (didn't touch anything) and now it doesn't work at all. I took it to the Pioneer local repair place and he said that I tripped a switch and he couldn't reset it unless I took in the large heavy 43' screen. It worked fine until I opened the set, Is there any way I can reset this switch myself? Thanks, JOE hello, i have the same problem but MR model is a pro-r05pu and i can,t get the display to turn on- the red lights on the display & MR along with the green on MR stay on (no blinking). the display model is a pro-435pu. any help will be very appreciated. thanks,
SOURCE: Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
SOURCE: Media Receiver will not work
took cover off my pioneer MR it's a pro-r05u and will not turn on - any one know the rest procedure for this model. the lights stay on - no blinking.
thanks,
SOURCE: HDMI inputs on my PDP-R04U are not working
From home set up on remote, choose option, enable HDMI.
SOURCE: My pioneer plasma tv is
My initial response is "An S-Video Cable"... but I suspect this isn't the information you are seeking.
You don't need to connect your receiver to the TV's video inputs UNLESS you want the receiver to switch between different video devices.
PS - more information on what "my receiver" is would help too, also tell us what you're trying to accomplish as the end result.
tell us about all the equipment you have, and how you would ultimately like to be able to control everything, and what inputs and outputs are on each device.
SOURCE: i have a pioneer plasma display pdp-435pu and
This model, according to what I have found from Pioneer, does not contain a TV Tuner. It is a multimedia Television/Monitor.
