Our aga does not want to ignite we follow th instructions on the door but the flame dies out after about 5 min the safety valve didn't trip what to do?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
We don't have that type of animal in our part of the country, O klahoma!
Posted on Aug 30, 2008
The pilot light ignites but goes out when the button is released, I have held it down for over a minute, can you help
The pilot light works with a safety cut out device should the flame ever get blown out. The device cuts the gas supply to stop accidents. If you look where the pilot light burns you will see a small metal looking tip in the flame, this is the device. It is full of liquid:that expands when the flame keeps it hot. The other end applies pressure on the cut out switch. The liquid within can fail. It is very easy to follow the tube to the cutout switch, unscrew the whole tube assembly and take to a hardware store for a cheap replqcement that you screw back in. Any excess tube carefully wind up in a coil, do not bend sharply as liquid will excape (liquid usually oil based) Once refitted ignite per instructions for your device. Happy fixing.
Sep 03, 2015 | AGA Kitchen Ranges
HI THERE I JUST BROUGHT A 30HP JHONSON MOTOR. ALL RUNS WELL BEEN OUT 4-5 TIMES. FIRST TIME WENT FOR ABOUT 30 MIN STARTED FINE BUT ON WAY HOME IT SPLUTTERD AND THEN DIED. BOUT 20 MIN LATTER IT WENT AGA
passably the cover on you motor should stop water from getting in or you got old fuel, or bought bad fuel if possible water in fuel tank buy a bottle of heat this will remove water from fuel tank, replace fuel filter if one or drain moisture trap on engine fuel system.
Apr 30, 2012 | Cars & Trucks
1993 Mercury Sable won't stay running
Seems that the fault relates to heating, check if the fuel pressure is dropping when the engine heats up, allow the car to idle so as to confirm . Also this will indicate if there is failure of the ignition system, This can fault in the ignition , failure of the HT coils.
What is important is your observation to the case before any part is replaced.
Oct 29, 2011 | Cars & Trucks
Having problem with the bake igniter not always igniting. Hear clicking, but no flame. Doesn't happen all the time.
You may have a weak igniter or a bad safety valve depending on the model. Let me explain. Their are many different types of oven valves. Some use glowbar and others use standing pilots, still others use a igniter with a safety valve and flame detecting switch. So you do not have a generic problem. To get a specific answer I will need the model number. Since you say you hear the clicking I am gonna assume that is a standing pilot with spark igniter nd safety valve/flame switch. In that case you either need to replace the valve if it is a combination one with thermocouple and valve all in one package or the flame detecting switch if your model has indeed a stand alone falme switch I have some repair photos: HERE
Jan 22, 2010 | Kenmore Ovens
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
Oven takes way too long to heat
This advice is for GAS ovens with glow bar type igniters. This is how to determine if the igniter is bad. This is a fairly simple repair that MOST do-it-yourselfers can accomplish with just a little guidance.
An igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad. An igniter should only take 30-90 seconds to ignite.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
For this solution, however, we’re going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
  1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
  2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
  3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
  4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
  5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
  6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
  7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
  8. Reconnect the wires using the recommendations mentioned in Step 5.
  9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
  10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models. I hope this information is helpful.
Mar 24, 2008 | Whirlpool SF315 Dual Fuel (Electric and...
When i turn on the oven the glow bar light up but seam like no gas is coming out of the burner
It sounds like you have a bad oven igniter. Over time an igniter will age and will not draw enough current to open the gas safety valve. This is why you won't hear any gas flowing. This is actually a designed safety feature that prevents free flowing gas from accumulating in your home without ignition.
There are two basic types of igniters:
If you need to replace an igniter, follow these steps:
6. Unplug the old igniter and remove the mounting ***** holding it to the gas manifold.
If you need further assistance, post back with your questions/concerns. I hope this helps you.
Mar 10, 2008 | Kitchen Ranges
Whirlpool SF365pegq
The way the ignition system in most of today's ovens work is like this:
1. Set the oven or broiler temperature.
2. The igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
5. NOTE: It can take roughly 30 - 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
Carborundum (Cylindrical in shape) - needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) - needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn't light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it's an easy assumption to make that the igniter may be bad, if one or the other doesn't light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn't produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won't light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we're going to assume you have a bad igniter and need to replace it. Follows these steps:
2. Open oven door and remove (if possible). Refer to your owner's manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn't shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 - 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2008 | Whirlpool SF369 Gas Kitchen Range
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
