Question about Sherwood RX-4103 Receiver
Pioneer vsx-c300 I managed to short out my right channel when adjusting my speaker wires.  The wires (+ & -) managed to touch and now the channel is dead.  Is it possible to repair such a brain fart or am I doomed to listening only out of the left channel?
  • Sherwood Master
  • 5,309 Answers
Yes, don't worry it's a very common to touch wires. The problem is that it will have taken out the two output transistors or the IC. Depending on the type of them you might pick them up cheap or they might be expensive, it will be the same for it being repaired in a shop. The only way to tell would be to look at the numbers on the device(s) and google them, you should get an idea of what they will cost.
Posted on Feb 20, 2009
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Pioneer VSX 42 Elite receiver will not stay on
Your unit is going into protect mode. More than likely it is an issue with a channel. Check the back and make sure your speaker wires are not touching anything they shouldn't be. Also check your speakers as well for any wire shorts. If all checks good, you probably have a blown channel.
Jun 20, 2012 | Pioneer Audio Players & Recorders
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
On my Pioneer vsx-55txi, the protection circuit cuts in whenever I raise the volume to a reasonable level. If I sit 10 feet or more, the volume is too low. I don't like my music or movies loud, but this...
The protection circuit is enabling because the output transistors are 1. drawing too much current causing them to heat-up 2. the transistors are going out 3. the threshold level for the quiesce state is set too high and may need to be adjusted internally. Try to cool down the Unit and see if it occurs again.
Nov 28, 2010 | Pioneer VSX-55TXi 6.1 Channels Receiver
I had a bad speaker wire on my Pioneer vsx-305 and the 125v 6.3a fuse blew. Where could I find a replacement fuse?
You can get fuses from any electronic parts shop, such as Maplin (UK) or Radio Shack (USA). I would get a few, because chances are the fuse did not just blow because of a bad speaker wire! Fuses are there to protect the device from an overload (which would cause a fire). The mostly likely cause of your fuse blowing is that your wire shorted out an output transistor on the channel the speaker was connected to and the transistor is acting like a piece of wire now!
If you have an Ohm meter I would put it's probes on the terminals of the transistors on the heat sink. You will soon know, as it will be just like you have touched the meter's probes together!
Apr 25, 2010 | Pioneer VSX-305 Receiver
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
New pioneer vsx-517 keeps going into overload
Fastest way to test is to disconnect all speakers and turn up the vol. If it clips it needs service, then re-connect 8ohm speakers one by one and test until you find the speaker or channel that shorts. Then take that same speaker and hook it up to another channel and test, if it shorts, you know now it is either the speaker or the wire. Now, use a new piece of speaker wire from the same channel that caused it to short, replace the old and test. If it shorts, you've got a problem with the speaker. If your handy with a multimeter, check the resistance at the speaker and you will have your answer. If you are not familliar with a multimeter, just hook up a different speaker where the bad one is and test. It's just process of elimination. Hope this helps
May 25, 2009 | Pioneer VSX-517
Speakers for pioneer vsx 1018
I think you're making this way more complex than it is.
This unit should have no trouble with any reputable speaker. Don't read too much into short term impedance readings as long as you run only one speaker per channel. Every speaker has a dip somewhere in its frequency range and the Pioneer will probably protect itself and the speaker should impedance or current get too out of whack. This is a high end unit and has plenty of clean power to feed any speakers out there.
I'd buy it if I didn't already have a 6-year old predecessor (VSX-T36TX) that I paid twice as much for and has only 5 amplified channels, less features and lower power output. ;-(
Good luck and happy listening!
Mar 28, 2009 | Pioneer VSX-1015TXK Receiver
Pioneer vsz 517 reciever powerd off wont come on
I have a VSX Pioneer. Somewhere either in the back of the rfeceiver or one of the speakers there is an errant wire touching the frame. Check the back of the receiver ald all of the speaker connections. The message is to protect the speaker, but can tke out a channel on the receiver if not corrected.
Apr 12, 2008 | Pioneer Audio Players & Recorders
Sherwood RX-4103 Receiver Logo
70 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
