Question about Maytag PYE2300AY Electric Dryer
Dryer i just replaced the element and high thermal switch and replaced the other low thermal and i ran the dryer without clothes for about 10 min. ok, i put a load of clothes in it and left it running and for some reason it shut itself off again
  • 943 Answers
HI YOU MIGHT JUST HAVE A VENTING PROBLEM iF YOU REPLACED THE THERMAL FUSE & IT WENT AGAIN tHE VENTING SHOULD BE LOOKED AT tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Posted on Sep 12, 2008
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
My dryer works for the first 10 min then goes cool
Sounds like a bad thermal limit switch which cuts off the heating element above a certain temperature. The switch could be malfunctioning, opening at too low and temperature and not closing after it cools down.
Charlie
Aug 14, 2009 | Whirlpool WGD6400S Gas Dryer
Limit switch burns out
Bravo on your troubleshooting, however, it is strongly recommended that if the hi-limit thermostat and/or the Thermal cut-out are defective that you replace BOTH components at the same time. That's why they are commonly sold as a set. Failure to do so can result in premature failure of the components you just replaced. In addtion, before you replace any components, make sure the dryer exhaust vent ducting is clear and free of obstructions. This is usally the cause of most dryer failures. This will cause the heating circuits to overheat, which is usually why the TCO or hi-limit thermostats fail. Let me know if you have any questions. I hope this helps you.
May 04, 2009 | Dryers
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
