Question about Bosch SHU9925UC Built-in Dishwasher
Bosch dishwasher Washer is in pump mode
My SHU9925UC/14 will not drain and leaks hot water from underneith.
Posted on Jan 17, 2009
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Bosch dish washer does not pump out water before drying cycle
either the pump is faulty or there is a blockage in the outlet drain.
if you hear pump working then clean the filter and the kitchen drain. If pump is not working then replace it.
Oct 06, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My washer will not drain the water I think that the pump has gone out in it is it going to be cost efective to put a new pump in it or should i just replace the entire unit
You could just need to clean out the sump if the drain pump impeller is jammed. Below is a link to a video you can download that will show you how to repair a Bosch Dishwasher that isn't draining.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/bosch-dishwasher-not-draining/
Good luck
Feb 28, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
No water is getting inside my Bosch dishwasher compartment. Water supply to dishwasher is ok. Checked hose at input of dish washer and water supply is ok. Could pump have packed in? Model 004 920 378....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Bosch Dishwashers
Water wants to drain and keeps trying
Sounds like anti flood system has triggered (polystireen float and micro switch) that puts the washer in pump out mode only and shuts the inlet water off. You need to look at the bottom of the washer and check that water leak / spill is not causing the float to activate. Clear the water and fix leak (pipe or pipe clamp) and this should fix the problem.
May 18, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Bosch shu9925
take bottom front panel off to expose the bottom tray. you will find there is water in it. mop water out and appliance will operate ok. turn off at mains first.
if fault reoccurs, you have a leak which will have to be traced
Aug 30, 2008 | Bosch SHU9925UC Built-in Dishwasher
Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Jul 13, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Bosch dishwasher
is all the water draining from the tub? if not the pressure switch will not reset and it will continue to try and clear it self...check drainage system.
2. pressure switch is jammed on..build up in the sensing chamber..common..or switch faulty...rarely
3. if water is in the bottom panel most have a flood switch which automatically operates the pump in case its over filling
Dec 04, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU9925UC Built-in Dishwasher Logo
284 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
