Question about KitchenAid Washing Machines
Kitchenaid top load washer pumps out water but the tub won't spin. How do you get the cover off and determine the spin problem?
  • 639 Answers
Friend,
ngfam1 At your service!
Sounds like a belt or linkage from the transmission to the agitator! OR THE TRANSMISSION!!!!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
Whirlpool top loading washer, LXR9245EQ2, quit agitating, spinning and makes a clacking noise, pump looks like it's still holding the water in the tub though and won't pump out?
There are two clips that hold the pump to the motor, remove it and inspect, turn pump axle in either direction. If not replace the pump. However if you remove it you may find a sock or something in which case you can remove item and put back into service. If jammed you need to replace with a new pump. Good luck, masta tech
P.s.if water remains in tub it has something blocking it, be ready to capture any water in tub when removing hose clamps. If it a small amount you may be able to just lean it backward to hold water.
Aug 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Water pump failed difficult to turn tub
I THINK YOU MAY NEED TO BUY A NEW PUMP FOR YOUR WASHER. OR IF YOU CAN FIND A OLD WASHER THAT IS THE EXACT SAME MODEL AS YOURS, MAYBE YOU CAN TAKE THE PUMP OFF OF IT AND TRY IT ON YOUR WASHER. IF THAT FAILS, THEN BUY A NEW PUMP.
RODNEY
May 15, 2009 | Maytag PAV2300 Top Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Water wont drain
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
**Take the front cover off and you will find brake pad pieces in the bottom.
Now some say you have to pull the center out to replace the pads...I don't. Here's how I do it..
Remove old screws were brake pads use to be and loose them! Kits comes with new screws that you must use. The transmission will turn free without the brake pads. You will need a 3/8 stubby ratchet. Insert 0ne pad in place toward the front and line up holes with front set of holes in mounting plate. NOW....spin trans around until the pad is near the back set of mounting holes. I use an Allen key to align holes and put rear screws in. Once you get the back one in the 2 front ones are easy. Don't forget to bring a new belt with you!!!!!!!!!!!!
NOTE:.....You must coat the new brake pads with a little silicone grease**
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 20, 2008 | Amana NAV5800A Top Load Washer
Hi, I have a 5yr old Amana Distinctions Super Capacity Plus top load washer, 2spd motor, 3.3 cu ft. I have taken off the front cover to expose the wash tub, because recently when the washer is in a spin...
sounds like a drain pump issue, not able to remove water quick enough before the centrifical force of tub spinning throws it over the top, remove the pump hoses and look for blockages
Nov 07, 2008 | Amana Washing Machines
Washing machine
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 18, 2008 | KitchenAid KAWS850L Top Load Washer
Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
Spin Cycle
HP, sounds like your washer is not going through the neutral drain. After agitation the tub should drain for about 90 seconds before going into spin. You can verify this by doing a load with the lid up and holding the lid switch down with a small screwdriver. If it fails to go into the neutral drain, it's a gearcase problem and should be covered under warranty for 5 years. If it does go into the neutral drain, then it's another issue such as the pump or drain hose....Catriver..post back
Dec 20, 2006 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
