Question about Epson Stylus CX4200 All-In-One InkJet Printer
Ink cartridge changed but computer will not recognize it has ink
I have changed the ink cartridge on my epson Cx4200 but it will not recognize that there is Ink
  • Epson Master
  • 1,879 Answers
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Posted on Aug 30, 2008
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges '
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to change ink in a canon cx4200
Just follow this link to view the user guide available from epson. Then click on 'removing and installing ink cartridges' link.
If you have any issues let me know.
Thank you,
Jul 16, 2010 | Epson Stylus CX4200 All-In-One InkJet...
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
I need a cx4200 printer owner's manual. I cant find where it is on the net..I need to know the steps to replace ink cartridges. Bob C.
Have you tried " Epson Stylus CX4200 manual" on Google?...
Go to:
You have all the documents there, including a User's Guide.
Oct 25, 2009 | Epson Stylus CX4200 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Have epson all in one cx4200. replaced all ink cartridges. on light and ink light remain on but will not print
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
My epsonstylus cx4200 wont print with black ink.
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Feb 09, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
205 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
