If the unit will only pump to 40 psi. then here are a few things I would check...
Check the air filter to make sure it is clean so air can be pulled in easily...
Check the relief valve to make sure that it has not gone bad and is releasing the air pressure or leaking at 40 psi...
Make sure the any hoses or nozzles are tight and not leaking...
If all of this checks out then the compressor has an internal problem such as bad rings or valves that will keep it from pumping to a higher pressure...
The pump will need to be torn apart to find the exact cause of the problem... and many times the correct replacement parts will not be available to rebuild those compressors..
heatman101
