LOL... I'll trade you, black for white... Seriously... Check the website of your frig mfg. and see what they offer, (they usuall snap off/on)..but NOT sure since we do not know what brand you have.. (If you are going to paint a large surface and what it beautiful.. contact a paint and body shop.. they will paint what ever you have ,, and do a great job) .... PLEASE do not "spray can" your kitchen appliances... sooo tacky...
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
SOURCE: Whirlpool Side By Side not making Ice, but water dispenser works
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the
icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with
this miracle fix of using a hair dryer to melt the frozen water line
going to the dispenser output. This is highly unlikely for our model
since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't
enough water pressure to trigger the solenoid valve. $40, and still no
luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage
going to solenoid, so I wasted $30 for a new solenoid.....still no
water.
-4th thing was I ordered a new IR sensor and receiver (since the
reciever end is where the relay that sends the voltage to the solenoid
to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF
THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch
underneath the freezer unit and disconnected, and removed the freezer
unit to inspect it further.
When I removed the protective white cover that covers the mechanical
wheel, I had a few parts come flying out of it. Turns out that the
wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE
FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48
BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS
BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10
times it will fix your problems. All techs replace the IR set at the
same time too which will set you back another $58 bucks.
Good luck! ;)
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
