Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Freezer leaking water
Water is leaking into the bottom of the freezer which is then turned to ice but will leak out with in a couple of days. Frididaire FRS26ZSG. Not sure what is causing the leaking. water freezing up in the bottom of freezer water leaking onto floor
  • 2 more comments
  • wildflower66 Oct 04, 2008
    My ice maker is not working but the water dispenser on the door is working fine. I too have water in the bottom of the freezer which also drips out onto the floor from the front of the freezer door. I have tried shutting off the freezer and allowing it to de-frost but this has not solved the problem.
  • Anonymous Mar 13, 2014
    Water is leaking from the inside and running to the bottom of the freezer and out onto the floor. What is wrong with the unit?
  • Anonymous Mar 16, 2014
    Water is freezing on bottom of freezer then leaking out onto floor
  • Anonymous Mar 24, 2014
    bottom freezer is leaking water everywhere onto my floor.
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Posted on Sep 19, 2008
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Water leaks every 5-7 days from the freezer. I
If your water valve is not closing properly, it will do that. The water valve is not very expensive. If you have ice and water in the door, there are 2 water valves. Replace BOTH! If one is weak, the other is not too far from giving out too.
Jun 01, 2010 | Refrigerators
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
The icemaker leaks water from the fill tube into the fridge
my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
1,194 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
