Question about GE Hotpoint 21.8 Cu. Ft. Top-Freezer Refrigerator
Refrigerator Leveling Problem
My GE top freezer refrigerator makes a vibrating sound which leads me to believe the unit is not properly level. When I touch the door, the sound stops; I have had it leveled professionally, but the noise has returned; it is quite annoying.......any special suggestions
  • ajp0208 Aug 31, 2008
    took the whole unit apart......found a grate on the back of the fridge.....think this is what was vibrating.....so far so good....thanks for the help.
  • 706 Answers
Buy an inexpensive spirit level ( regular level sold everywhere) and check the level for yourself.. If you push/pull on the fridge..does it rock at all.. if so.. it may be level but the adjustable feet aren't making contact sufficiently to keep it from moving.. If after you've verified it is level.. you can do a few diagnostics on your own.. you can try removing everything on the door inside.. then listen for that noise.. if still there.. remove shelves and food etc.. see if it is still there.. check the snap on grill at the bottom to make sure it is secure.. check the hinges on the doors and make sure everything is snug.. make sure ther isn't anything on top of the fridge that might be vibrating when the fridge cycles.. You have many options here.. Hope this helps..
Posted on Aug 31, 2008
My refridgerator is dripping water inside of it.
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Apr 04, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Getting water in the bottom of the ref is a top freezer model with ice maker in freezer.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jun 13, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
MY KENMORE TOP FREEZER DRIANS DOWN IN TO THE FRIGERATOR, DOES NOT DRAIN DOWN TO THE PAN, IT STILL WORKS GOOD BUT I HAVE WATER SITTING IN THE FRIG.
Hello.
May 13, 2010 | Kenmore Refrigerators
TOP MOUNT FRIDGE WATER LEAKING INSIDE OF UNIT UNIT STILL COLD. WATER DOESNT SEEM TO GET DOWN TO THE PAN
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
Mar 22, 2010 | Kenmore 21.7 cu. ft. Top Mount...
Water leaking and also freezing underneath veggie bins
Jan 05, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
GE refrigerator side by side water comes our sporadically under the door appears to have nothing to do with the water dispenser. May happen in the middle of the night or while we are away at work. Both the...
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking inside refrigerator
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Dec 07, 2009 | Frigidaire FRT21H8 Top Freezer...
Water running into refrigerator I think on defrosting
Oct 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water is leaking into fridge-freezer getting frost around door I believe it is a roper RT21AKXKQ
Oct 22, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refridgerator leaking water on the interior
Aug 03, 2009 | Whirlpool ET4WSKXS Top Freezer...
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
