Question about Lands Phones
Can't register the handset
It says handset needs registration, an when i follow the instructions it won't do it , ge25952ee3a
GE25802G3-A
Posted on Sep 06, 2008
Binatone 1910 flashing not registered to base
Registration:
Instructions if you need to register handsets to the base:
You can register additional handsets to have up to five handsets per base unit, with each handset's number (1 to 5) shown on its display.
1. Press and hold <PAGE> on the base station for more than five seconds to put the base station into registration mode. (Note: there is no feedback to know it is in reg mode.) It will stay in registration mode for about 1 minute. So complete following sequence within this time. (It helps if handset is kept very near to the base during this).
2. Press <MENU> and <UP/DOWN> on the handset to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING. If the handset registration is successful, you will hear a confirmation tone and the <antenna icon> will stop flashing. This may take a short while. The handset will automatically be allocated the next available handset number. This handset number is shown in the handset display in standby mode. If thehandset registration is unsuccessful, the <antenna icon> will still flash and the display will return to ' REGISTER', so you will need to repeat registration process.
Mar 24, 2014 | Binatone Lifestyle 1910 Twin Cordless...
I have a uniden TRU9488 preregistered handset from factory, which for years no problem, but stupid me thought "what is this register" and hid register, and now my handset won't work. followed...
What happened is you have deregistered your handset from the tru9488 base. To correct this, you must register that handset with the base. See https://www.manualslib.com/manual/185023/Uniden-Tru9488.html?page=24 for short and sweet instructions for doing this, reproduced below:.
Registering.TCX905.Accessory.Handsets,.or.Other.Compatible.Handsets If.you.purchase.an.accessory.handset,.you.need.to.register.the.handset.before.use..Only.one.handset.can.be.reg-
istered.at.a.time..Handsets.supplied.with.the.phone.are.registered.to.the.base.by.the.factory..When.charged,.pre-
registered.handsets.display.a.handset.ID.number..Handsets.that.have.not.been.registered.display.MODELS.VARY!.
PLACE.HANDSET.ON.THE.BASE.FOR.REGISTRATION.OR.REFER.TO.OWNER'S.MANUAL..(If.an.accessory.
handset.has.ever.been.registered.to.a.base,.you.must.reset.the.handset.before.you.can.register.it.to.a.new.base..
See.Resetting.the.Handsets.on.page.24.)
When.you.register.an.extra.handset.to.the.base,.the.handset.ID.will.be.assigned.
M o d e l s v a r y !
P l a c e H a n d s e t
o n t h e b a s e f o r
1)
Before.registering.the.TCX905.or.other.extra.handset,.the.battery.pack.MUST.be.charged.for.5-20.hours.
2)
With.the.base.in.standby,.press.the.MENU.soft.key.
3)
Move.the.cursor.to.select.REGISTER.HANDSET..Press.the.OK.soft.key.
4)
On.the.handset,.press.and.hold.[#].until.you.hear.a.beep.
5)
While.the.handset.is.registering,.HANDSET.REGISTERING.will.appear.in.the.dis-
play...
When.REGISTRATION.COMPLETE..is.displayed;.the.handset.has.been.registered.to.the.base...
If.REGISTRATION.FAILED..appears,.please.try.these.steps.again.
Aug 10, 2017 | Uniden TRU9488 Phone
I switched handsets and renamed them, but my calls are still going to my old handset. How do I fix this issue?
You will need to se-register the handsets you are getting rid of...on the base unit go to initial settings-registration-deregister handset. Deregister the handset #'s you are trying to swap (the number is just left of the name on the handset display). Then register the 2 new handsets (on handset: menu-initial settings-regitration) and on base menu #123. Follow instructions on screen to complete registration. This should activate your 2 new hansets and de-commission the old ones.
Sep 25, 2010 | Panasonic KX-TG4500 Phone
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
Can't register new handsets
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Apr 10, 2009 | Lands Phones
Tried to reregistering
Hi
Please try the following procedure:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
Registration problem
download the user manual from the motorola web site for your model
May 27, 2017 | Motorola Mobility Lands Phones
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
My new hand set will not detect my base
Have you followed the instructions for handset registration? For some of the newer handsets, you may need to refer to the instructions that came with the handset (and not the base) instead of just putting the additional handset in the base to register it.
Page 23 of the 9480 manual gives explicit registration instructions.
Jan 07, 2008 | Uniden TRU9480 Cordless Telephone
Lands Phones Logo
344 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
