Question about Legend LA1490 - American Legacy Series 2 - 1400 Watt High Performance 2 Channel Amplifier Car Audio Amplifier
Hey thanks alot for the help, the way its hooked up now the amp eventually gets way to hot and the shut-off saftey heat switch just comes on. wondering if you had any suggestions for a good amp along with a good price let me know thanks.
    Problem Solver:
  • 6 Answers
First of all sorry for your problem but if you ran the ohms to low it will get hot and even burn up if it dont shut itself down. I like the crossfire amps like a old cfa602 or cfa1000 they are very strong amps and underrated. I do car audio and a lot of people love this amp even the vr602 is great. If you dont have a lot of money go with a ssl3000 its about 160 on ebay
Posted on Nov 01, 2012
    Novelist:
  • 100 Answers
I would definately say, in the world of amplifiers you usually get what you pay for. I would recommend getting a Memphis or MTX amplifier. Go to ebay, specifically search for memphis then in the search options make sure to put in mono or 1 channel. All memphis mono block amps are 2 ohms stable. In particularly I would recommend for you the PR series. it is the Power reference series and they are really boomy for the money. Anything that has the "ST" is getting a little old so I wouldn't recommend it but It still is a good amp, just not sure how long it would last and how badly it's been beaten in the past. Good luck. If you find an amp and are unsure let me know which one and I can help verify it for you.
-Andrew Hawkins
Posted on Sep 02, 2008
What does external protection devices activated mean? ( EO code)
these are saftey swithes that are used say if your out door unit fan quits the compressor will run hot and shut off or if your indoor unit is stoped up the unit will run low pressure wich will shut off by the low pressure switch usually if its dirty or low on freon it will come on and off three times or so and will shut its self off.
Jul 20, 2014 | Daikin FDXS12DVJURXS12DVJU Slim Duct...
Amp shuts off then on
It's getting so hot that it's going into thermal protection. Turn down the gains of lighten the speaker load. The more speakers that hook up to it the more power it will put out causing the amp to overheat. Eventually it will burn up some of the output Mosfett Power Transistors.
Apr 01, 2013 | Power Acoustik Car Audio & Video
The fan turned on randomly and will not shut off
A make & model number would help...There could be a number of possible causes. The overheat saftey, depending on the make & model this senses ambiant heat on the frame / chassis, the door sensing interlock switch. Depening on the make & model the control board fan relay. All these could be shorted closed. Depening on how the fan switch is wired the on / off switch or the routing through the control board might be at issue. If the unit has a schematic it may help troubleshoot the issues.
Mar 28, 2012 | Maytag Microwave Ovens
I can't shut off the air coming out the valve on the bottom of the compressor. Is there something that blew out?
Sounds like a saftey valve has gone bad?????? These valves are used to prevent excessive pressure from building up in the tank. They are usually spring loaded by the manufacturer to a specific pressure. Sometimes however.... condensation builds up inside the tank due to the changing ambient temp. Compressors get REAL hot when they build up air pressure...... the higher the psi.... the higher/hotter they get! When a compressor reaches the its proper shut off point it stops, as it cools condinsation has a tendency to form inside the tank...... eventually dripping down into the bottom of the tank, forming a puddle...... which then sits there..... sometimes for a LONG time! This water/puddle is unfortunatelly right where the safty valve is mounted............. in THE BOTTOM OF THE COMPRESSOR! (exactlly where you indicated its leaking air?) in the bottom........???? The saftey valve has probably corroded due to moister inside the tank. Unfortunatelly this is a VERY IMPORTANT SAFTY DEVICE...... & SHOULD BE REPLACED WITH THE PROPER MANUFACTER RECOMMENDED PSI VALUE WHEN IT BEGINS TO HAVE ISSUES. Sometimes...... when lucky...... it can be removed, cleaned, & lubricated..... caution should be observed however..... should any pitting of the metal caused by excessive corrosion be observed during or after cleaning........ it should IMMEDIATELLY be replaced!!!!!!!!!! REMEMBER, THIS DEVICE IS THERE FOR SAFTEY REASONS!!!! DO NOT REMOVE IT FROM THE BOTTOM OF COMPRESSOR AND INSTALL A PLUG INSTEAD..... DOING THIS COULD CAUSE EXCESSIVE PRESSURE TO BUILD UP TO A POINT OF EXPLOSION!!!!!!!!!!!!!!!!!!! ONLY REPLACE VALVE WITH IDENTICAL PSI VALUE!!!!!!!!!!!!!!!!!!! Hope this helps & GOOD LUCK!
May 14, 2011 | Air Tools & Compressors
MODEL PYGT444AWW GAS DRYER LITES UP OK BUT SHUTS DOWN HEAT TO SOON ALONG TIME TO DRY
there is a saftey relay that might be bad and needs replacing.. this is there for keeping dryer from starting a fire or over heateng.. when the dryer start heating the saftey switch is on and once it stops heating the switch is open and and will not dry.. it could be a heating element once it gets hot it expands and will not heat..
Mar 25, 2010 | Dryers
My furnace is not blowing hot air when I turn on
Normally if you have a limit switch problem on a hot air furnace it is the manual high limit switch that should be located near the blower. If you lost power while the unit was operating the heat build up will trip this switch.
Normally they are about 2 inches round with a red button in the center. Firmly push the button till it clicks.
Sometimes it can be the high limit switch that is just a saftey switch in case the furnace gets too hot.
If you do not have enough air flow this switch will operate excessively and will eventually fail.
The best way to find the problem is to trace the low voltage control circuit till you find the open switch. This can be challenging and time consuming, especially if you are not used to doing it.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Heating & Cooling
My Heater Will not shut off
probably your heat sequencer is stuck open, and there is nothing you can do except replace it. Call a company and they can do that for you
May 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Slow idle after getting hot
how hot is very hot? heat management will ****** idle and eventually drop a cylinder but if you are getting that hot routinely something else is going on...I'm in Phoenix, ride alot and have only been in heat management 1 or twice in the past year+
Mar 17, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Power acoustik gothic ov2-1600
What are the circuit board designations (Q111, Q112, Q211, Q212...) for the parts you replaced?
Did you replace the defective parts with identical transistors?
Which transistors are heating up?
Nov 07, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Legend LA1490 - American Legacy Series 2 - 1400 Watt High Performance 2 Channel Amplifier Car Audio Amplifier Logo
152 people viewed this question
Top Legend Car Audio & Video Experts
xxxxxx xxx
Are you a Legend Car Audio and Video Expert? Answer questions, earn points and help others
