Question about Brother HL-2030 Laser Printer
Paper light flashes red...
Hi My
Brother HL-2030 Laser Printer has a paper light flashing. what should i do to get my printing print again? the light keep flashing even when paper is in and the lid is closed properly.
Thanks
  • malcrob Sep 02, 2008
    same problem, I moved offices and now the red light won't stop flashing, paper tray full and cover closed.
  • suzannemunn4 May 11, 2010
    no did not wrok what else can i try
  • 22 Answers
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Posted on Oct 30, 2008
Paper light flashing when paper tray is full
Paper got stuck in my HL2030 printer I cleared it but red light keeps flashing and won t let me print.
Feb 17, 2011 | Brother HL-2030 Laser Printer
My lamp "paper" blinkikg brother hl-2030
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.If the problem still exists, you may try this 2nd option.
> the front door. There is something wrong with the front door, or the mechanisms that signal that it is closed. Closing the front door (the one that you open to pull out the toner and drum) all the way to where it snaps into place then the paper light flashes red. However closing the front door to the point where the "ready" light comes on (don't snap the door into place, just close it and let it rest in place without snapping it closed) and the printer prints fine, pulls paper from the tray and prints like it should.
So give it a try, don't snap the front door all the way closed to where it snaps closed, just close the door to where it's resting closed to where the ready light comes on and see if this helps you.
Nov 20, 2010 | Brother HL-2040 Laser Printer
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
My Brother hl 2030 has a permanent paper led light flashing altho there is no paper jam and all covers are secure
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 09, 2010 | Brother HL-2030 Laser Printer
My Brother HL-2030 won't work; All LED lights are flashing
Use the software to diagnose the problem or check for a paper jam and ensure the drum and toner is OK.
Dec 11, 2009 | Brother HL-2030 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
HL-2030 Continuous Paper Light Flashing.
i looked at the service manuals, there is not one for the hl-2030, however for the hl-2040 is indicates that the front cover or back cover door is open, check the back door and see if the sensor is moving freely.
May 25, 2009 | Brother HL-2030 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother HL-2030 Laser Printer Logo
896 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
