Question about LG 52SX4D 52" HDTV
Light bulb flashes 3 times, TV won't turn on
The TV won't power up. The white light scrolls, than power light turns constant red and light bulb icon flashes 3 times.
  • brad ross
    brad ross Nov 08, 2008
    well i have the same problem... got a new bulb and still nothing.
    Problem Solver:
  • 16 Answers
Well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from light bulb flashes 3 times, TV won't turn on - s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
Posted on Nov 15, 2008
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Tv wont turn on
old technology, dump it. My work place at the airport just installed a 72" Samsung Ultra High Definition 4K flat television. Easily worth the $6,000 it cost.
Jun 17, 2017 | LG 62SX4D 62" Television
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at plopit40@yahoo.com
Nov 11, 2008 | LG 52SX4D 52" HDTV
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
May 14, 2008 | LG 52SX4D 52" HDTV
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
255 people viewed this question
Computer Repairing
Computer Repairing
