Question about Dishwashers
Bosch Exxcel Dishwasher
Hi greendude,
The problem is this:
The tablet is still in the dispenser after the full washing and drying cycle is finished. As said before I did try three different tablets (all good and expensive makes) and different cycles. I checked the spray arms and filter and they're all clear. I checked the tablet compartment, it is clear, I made sure that it was clean and dry before putting a new tablet, but the problem was the same.
Another website suggested that I put the tablet in the cutlery basket. This time instead of a tablet I decided to put one of those bottles for cleaning the dishwasher (that go in the cutlery basket anyway). After the cycle finished the bottle was still full with cleaning fluid and the membrane in the cap was still intact.
There is water in the dishwasher, I've checked mid-cycle and you can hear the sound. The dishwasher is hot when the cycle is finished, but don't know if this is because of the drying cycle.
The make is Bosch Exccel, free standing, slimline.
Could it be the element?
    Sergeant:
  • 351 Answers
No not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Posted on Sep 03, 2008
Testimonial: "Sorry about late reply. Thank you for your help."
Sgv5613gb
Bosch sgv5613gb will not finish cycle stopping on 1 minute and the dishers are not dry. Is it just a case of resetting the machine and if so how?
Jan 05, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
I have a Bosch Exxcel free-standing dishwasher that is not powering up. The fuse is okay and there is power at the switch and the PCB. None of the lights in the control switches come on. The dishwasher...
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 16, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap tablet not dispensing happens every 2nd or
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Bosch 24 in. SGS43E08 Exxcel Built-in...
Run full wash cycle and when finished dishes are not completely dryed so we need to air dry to complete - something is not right - any ideas. Thank you, Wade
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 06, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
The soap tablet is no longer fully dissolving in its compartment, still does so when placed directly in d/w but finish is not as good
Have a look at the top spray arm.
Dishwashers rely on the water coming out of the end to wash the powder (tablet) out of the dispenser. Other problem could be a low water level. This would need adjusting by someone who knows how for whatever brand/model you have. Hope this helps...
Dec 12, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Slimline dishwasher Exxcel. Detergent dispenser does not open during the wash
take door outer panel off and dispenser is exposed. start cycle and with a multimeter, check power comes to the dispensor during the cycle. if you get power, then the dispensor is faulty. if no power, then the module is faulty
Aug 05, 2008 | Dishwashers
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dishwashers Logo
259 people viewed this question
Top Dishwashers Experts
