Question about Gateway FPD1765 17" Flat Panel LCD Monitor
Fdp1765 problem monitor trys to turn on but goes back off immediately
  • mross_hope Jan 29, 2009
    The monitor attempts to display but immediately goes blank. I have verified that the problem is with the monitor and not any workstations it was attached to. I even tried a different VGA cable - same result... blank screen. Any ideas or solutions out there?
  • Victor Castro
    Victor Castro May 11, 2010
    Can you see a dim image?
Replace bad caps and reflow bad solder joints.
Posted on Oct 14, 2010
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
MY COMPUTER WANT START UP IT TRYS
The power supply unit is probably bad. (PSU) They can either turn on and turn off, turn on and when you start to draw power they shut off or not turn on. I'm guessing you need a new one, check to see if you have a warranty on the PC. If your sure the lights turn off and not just the monitor goes out.
Mar 30, 2013 | Acer Aspire Computers & Internet
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
My monitor wont turn on
hi, do you mean after you turn on then immediately turn off. tried to remove the supply going to the inverter board for screen back light just to ensure if the inverter board will be the cause.
Aug 04, 2012 | Computers & Internet
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
Oven will not stay on
sounds like the spark switch is gone out. have a technician replace it.
Sep 12, 2008 | Whirlpool GS475LEKS Gas Kitchen Range
Gateway FPD1765 17" Flat Panel LCD Monitor Logo
174 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
