Question about Acer Aspire 5600 Series 5630-6951 Laptop
Multi screen solutions
Someone says me that ur pc has gridvista.but i dont know i start it.plz help me.i have acer pc.
  • Anonymous Oct 09, 2008
    my acer aspire laptop has GridVista Multi-screen solution, but I don't have a how to turn it on. have tried searching the computer for these words to no avail.
    any ideas?
I cant connect using blue tooth
Start your bluetooth on PC and then in your HTC......I hope u have bluetooth software in your laptop......if not install it....try to search devices in ur laptop dont forget to keep ur HTC in visible mode. when ur laptop identifies the devices try connecting way that ur laptop gives a key n type the key on ur htc it will connect.....n u can strt data transfers easily......hope this helps......
Mar 11, 2010 | HTC Computers & Internet
3 icons in the corner that werent there caused by acer gridvista
i my own answer,,i think you can still open your grivista program by simply changing the setting of it..hope my answer would able to help you..
May 11, 2009 | Acer Aspire 1640Z Notebook
Volume My Acer Aspire One AOA110-1588 PC Notebook
If ur question is dat u dont have volume to ur laptop..Install the Audio drivers provided by the Acer eRecovery.I hope it will slove ur problem...If not restore ur laptop to factory setting.
Apr 14, 2009 | Acer Aspire One AOA110-1588 Notebook
Both screens wont work
No mention of how much ram installed ???
Are you using ACER GRIDVISTA
This program handles the multi screen out put
Standard Screen Properties,,,,,,,
Try this
DESKTOP>Right click properties
With both screens connected.
There should be two windows displayed ,
a highlighted white one and a grey one
Should display a number 1 on the screen it has attached.
Should display a number 2 on the external screen.
Once you get IDENTIFY to work then set resolution sizes of both individual screen.Apply and ok to save settings
If using GRIDVISTA then set the setting for the output functions and save theme as a theme BOTH or LAPTOP AND EXTERNAL MONITOR and its accessible from the desktop right click.
Good luck I have a couple of these I use for my Media Centre wirelessly networked thru the house.Great machines.
Jan 11, 2009 | Acer Aspire 3680 Laptop
Wifi connectivity problem
there are three levels of switches for this model
one is mechanical on side or front..check..
one is the network connections enable switch..control panel accessible...check..
third on is the repair this connection, bottom right on tray..right click to repair...check..
try that on for size
Oct 04, 2008 | Computers & Internet
Download the newest version of GridVista from Acer's website. This should fix you up.
Nov 26, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
