Question about Garmin StreetPilot C330 GPS Receiver
Street pilot is dead
It froze on day while using . Then it died. Does not turn on . will not reset .
  • Shail Kaveti Jan 17, 2009
    i have the same problem, my gps doesn't turn on.Does anyone have a solution?
  • 31 Answers
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
Our Garmin Street Pilot will not charge. Do the
The batteries DO die after a time. They are not designed to be replaced by the user. If you believe your battery has died, you should contact Garmin.
Jan 05, 2010 | Garmin StreetPilot C330 GPS Receiver
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. http://www.garmin.com/garmin/cms/site/us/support/supportcontactand the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Dead battery on Garmin Street Pilot C330 - Who can fix this?
My Garmin c330 just died and wouldn't come on when I plugged it in. I tried the reset button after taking off the face plate with fingernail right where it says garmin. Then I plugged in computer with usb and it worked. I will try in car, but the problem might be the fuse in car charger, I looked in manual and it shows how to replace. So I will go to radioshack to get new fuse.
Aug 22, 2008 | Garmin GPS
Garmin Street Pilot C330 - Produces Deafening Noise!
suddenly froze can not turn it off what to do thanx
Jul 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
pull out the faceplate by gently pulling it from a little slot under the logo (top - middle). you will see under it a button labeled "reset"
Apr 06, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT 320
To unlock a “frozen unit,
1. power it off
2. Remove the face plate, Gently pry on the face plane. In the center top edge (under the Garmin logo) you’ll see a small notch.
3. on the right side of the unit, press the reset button.
4. replace the face plate
5. Power it back up.
The unit should restart normally.
Mar 21, 2008 | GPS
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
171 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
