Question about Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery
15 MINUTE AA CHARGER
IT TAKES OVER 1 HOUR TO PARTIALL CHARGE BATTEREIES. DOES THIS PRODUCT WORK? IF NOT WHAT CHARGER WILL
  • sjrees May 11, 2010
    Are the batteries Duracell brand nihi batteries? How long do they sit between charging and being used? (duracell says their nihi batteries can only be stoerd a month after charging before they lose their charge; 3 weeks if installed in a device).
Call duracell and explain your problem they will likely send you new batteries. They will tell you that yours are old.
Duracell if the the USA (800) 551-2355
Posted on Sep 08, 2008
HOW DO YOU CHANGE THE BATTERYS
Depends on what battery. car battery I charge with i 10 means with a current 1 / 10 of the capacity in Ampere hours for 14 hours. So a 80 Ah battery with 8 A for 14 hours.
A camera battery in the charger I got with the camera. Or a good universal charger from GP. A NiMH AA or AAA battery, with a quick charger that at least needs 2 hours to charge. The quick chargers I have that can charge in less than 2 hours (one can manage in 15 minutes) all kill batteries after a few charge cycles. Hope this helps.
Mar 15, 2015 | Cameras
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
Dec 27, 2010 | Duracell AAA NiMH Battery Charger with 4...
Battery, 8.4V 900mAh NiMH 7-Cell. Works with RC Airplane Models: Commander: how long does it take to charge?...
Hi
From the picture this looks like a Firebird product? If you're using the AC charger that came with the product, charging is usually overnight. If you're using a generic NIMH charger then 15 - 20 minutes is normal but its all based on your charger.
May 11, 2010 | Challenger Battery, 8.4V 900mAh NiMH...
Can u charge camera with usb cable from computer
The Kodak camera that I own states in the manual that you can charge the batteries only with the printer/dock or separate battery charger. I've left mine plugged into USB for hours at a time and never noticed a charge going into the battery. I use both AA lithium-ion batteries and the pack that came with the camera. The Li-on AAs work as well as the pack and for a cheap price, I purchased 4 AA and the charger (about $15).
Nov 28, 2009 | Kodak Easyshare M753 Digital Camera
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Dec 11, 2008 | HP Photosmart M547 Digital Camera
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
FinePix E500. 4.1 : model # BL00402-200(1) E
Indeed you can!
I would recommend against using any of the older NiCAD batteries, however.
The newer (and - BY FAR - more efficient) standards is NiMH batteries. (Nickel Metal Hydride.)
I used to be an Energizer fan myself... But as I worked in electronics retail, I tried many different brands of batteries with our products. I actually hated Duracell because of the crap quality of their older product lines.
But eventually, I had to grudgingly admit that Duracell batteries were far superior to any other brand currently on the market. (No less expensive, however. Pretty much the same price.)
I use the 15-minute charger currently available from Duracell. It cost about $30, but it comes with 4 AA batteries with a rating of 2400 mAh.
This rating is basically what determines how much of a charge the battery can hold. The higher the rating, the longer the battery will last.
I also bought an extra pack of 4 AA's while I was at it. I bought all of this for my digital camera. (Canon S3 IS.) The batteries in the extra pack had a higher rating of 2650 mAh.
Even using the 2400 mAh AA's, my camera lasts for a few DAYS of continual use! I will admit that I rarely use the flash on my camera. But even with the flash, the batteries last several hours with continual use. The 2650 mAh batteries last even longer. (Yes. I have monitored and recorded usage vs endurance. I know. What a nerd I am, eh? :P )
Perhaps you've had bad luck with Duracell before, but so did I. I'm still not too fond of their alkaline batteries, either. Perhaps you should consider giving the Duracell rechargeables a try?
Click HERE to see the product I bought on Best Buy's site. (I bought mine at Walmart, however.) It is the 15-minute charger system. It works with both AA's and AAA's. (I had to really inspect the device after I bought it to see how it recharges AAA's though. But it works great.) It actually does charge in 15 minutes, too. Every time. It's so powerful in fact that it uses a fan to cool the batteries while it's charging. Now that's awesome. :)
Remember to make sure that you give the batteries a full charge before you use them. Also make sure that you don't charge the batteries again until they're completely drained. Otherwise you will significantly decrease the charge capacity of the battery. Duracell has an excellent guide on their site on how to lengthen the life of your batteries. (I just found it trying to look on their site for their own product...which I did not find. Good batteries, crappy web site. Bleh...)
Click HERE to see this spiffy guide. It actually contains excellent information.
Otherwise, you can try any other brand that you prefer. Energizer is still second best, followed by Rayovac. (This is from my own experiences, of course.)
Let me know what you think. :)
Cyryl
Nov 10, 2007 | Fuji FinePix E500 Digital Camera
Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery Logo
329 people viewed this question
Top Duracell Electronics - Others Experts
Craig Butler
Craig Butler
Joseph Mueller
Joseph Mueller
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
