Question about Dryers
Dryer overheating Dryer is overheating and the door pops open back element is red hot.
  • mannkival Sep 11, 2008
    dryer overheating and the back element is red hot!!!, i changed the thermal fuses but i still have the same problem
  • 639 Answers
Friend,
ngfam1 At your service!
STOP DUE NOT RUN THE DRYER!!!!!!
FIRE HAZARD!
CALL SERVICE!!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
My Inglis dryer is overheating. How do I troubleshoot this problem? Thanks...
did you remove the metal duct to the left of the t-stat and thermal fuse?usually this gets filled with lint and will take out either the thermal fuse or the high limit,pull it off and clean it,also if the vent line is long,you can stick a leaf blower into the end of it and blow it out.most problems i find in dryers is from lint buildup.
Dec 06, 2011 | Whirlpool Inglis IP8200 Dryer
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Heating element
if it does not stay red after you open the door then it's ok. but opening the door in mid cycle is not a good habit. turn off heat for a minute first will help the elements last longer.
Jun 12, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Dryer runs but doesn't dry clothes.
hi,check to see if element gets hot,run dryer for 5mins. open door and look at back of dryer.you should see a red glow.or you should feel heat.if not the element needs replaced.and make sure the tumble is tumblering. a dryer can sound like its running,but nothing is really happen.
May 29, 2009 | Dryers
Heating element only turns red when dryer door is open
You are correct you do have a dead short on the element.You need to replace the element.Hope i fixya :)
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Overheating
your element should shut off when dryer is not running.their is a short somewhere.could be timer or even the motor switch.
Mar 11, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryer to hot
the element is grounded to the element housing need new element and thermastat kit
Apr 08, 2008 | Whirlpool LEQ9858P Electric Dryer
TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Mar 14, 2008 | Dryers
Dryers Logo
291 people viewed this question
Top Dryers Experts
