Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier weathermaker 8000
I just bought a house with system in it and I cant find where the filter goes they dont have one in it and there is dust all over my house now. the owner had alzheimers. Thank you very much
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Is this an up flow system,(vents in the ceiling) or down flow, (vents in the floor?) As always, theres a place to add filters , before the fan on the suction side! No telling how long this been running without the filter and already contaminate the freshair system.. This is supposes to be checked out by the building inspector before you buy any house,Just talk it over with the Realestate Agent , have the full system cleanned and send them the bill or talk to your big brother the BBB! Thank-you-very-much!
Posted on Aug 30, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
My A/C (Carrier weathermaker 8000 hybrid) is not cooling properly
set the t-stat low and let it run for 5 minutes , stick a thermometer in the return air closest to the unit as possible until you get a good reading , then stick the thermometer in the cold air supply again closest to the indoor unit as possible let sit until it stops going down in temp.
this is called your temp difference and it should be atleast a 14deg. F difference from in to out. if its lower you have a refrigerant problem, Let me know how it goes.
Phil
Jun 10, 2009 | Heating & Cooling
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
I need to change the filter in my Carrier Weathermaker 8000. WHERE IS THE DOOR?
There is a filter on the bottom of the unit. You will either have to remove the bottom panel in the front. Or thereis a thin acess panel down in the front of the unit.
Oct 24, 2008 | Heating & Cooling
Carrier 8000 weathermaker filter
The filter should be located in the front there should be some kind of tab to pull out the filter.
Oct 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Dec 31, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,025 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
