Question about Philips MCD288/37 DVD Micro Theater System Theater System
Philips stereo stopped working
I've had my stereo connected for 1.5 yrs now (since I bought it) and had no problems. However one fine day it just decided to stop working i.e. the lights normally displaying a 'welcome' message on the set wont even turn on.
I checked the AC power cord and tried using other power outlets and don't believe this is the problem as I hear the speakers making a slight connection noise when I turn on the power switch.
As such I think it can only be the 15 pin D-sub cable or the stereo itself that is faulty. Can you suggest anything else or how to fix it?
(FYI - I bought the unit in Singapore but am using it in London now)
Much appreciated
  • Anonymous Nov 30, 2008
    My system has also stopped working same wasy suddenly one fine day.No solution yet.
  • 51 Answers
SOURCE: Need speaker connection diagram of Philips HTS6515
You will not get anything to do like that sir,
But you can do one thing, thats you can tap the wire of speakers to get a connections extra to join the speaker separately,
but here one drawback is there when you do like that the company people wont provide the warranty just keep in mind, because here there is a physical damage, for physical damage no company provide the warranty.
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: My HTS3400 DVD Home Theater stopped producing
if you do a search on HTS3450 (same unit) you will find a thread with similar problems. My problem was similar and today I fixed it by changing 2 capacitors in the unit.
Posted on Nov 30, 2009
SOURCE: Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
Posted on Oct 06, 2010
  • 2382 Answers
SOURCE: My philips hts3372d wont turn
Hi, this is likely because of Bridge problem in power section in the player, thats why its not turn on. There is diode issue in the power section its called bridge rectifier, so please check with this. It can also be as a result of a burnt fuse that needs to be replaced....
Posted on Apr 18, 2011
SOURCE: cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Posted on Dec 06, 2011
Car stereo not receiving power.
Sound system w/o amplifier. Not only check the fuses, check the fuse circuit for voltage, use a test lite. As you can see, one fuse is hot all the time, the other fuse goes hot with the key on. Also check ground wire, that wire color is black.
May 05, 2017 | 2006 Kia Rio
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Channel 2 doesnt work. Channel 1 works perfectly fine and i have been using the mixer for abt a yr and from one day to another channel 2 stopped working.
did u find any solution with the mixer? I have a similar problem. Channel 2 works great, Channel 1 is sending only the Left side, something like Mono instead of Stereo.
Feb 21, 2010 | Nu Mark Numark Dxm01 DJ Mixer With Two USB...
1 Answer bought a surround sound set up, which audio output port do i use on the tv cos neither seem to work
This model has two audio outputs. The Monitor out has Video + L and R - L & R are normal stereo and should carry any surround info.
The single RCA Digital audio out must connect to a COAXIAL digital input on the amp.
Dec 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
White lines appearing on the screen also FIFA 09 problem
i dont care and stop asking ps3s are crashing and call sony no one here can fix these problem so save urself time and call sony
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
Aug 07, 2008 | Audio Players & Recorders
Clarion DXZ655MP Speakers worked then stopped...
sounds like the ohm load of your speakers is incorrect and overloaded the amp,....check all your specs, i.e. max, min ohm load on stereo, and speakers,...this stuff is important and must be within the range allowed or stuff like your experiencing happens,'s happened to me before,.....fried my amp because i had house speakers in my van, was great for about 3 loud days,....good luck, cracklin joe,.......
Sep 26, 2007 | Clarion DXZ655MP CD Player
Philips MCD288/37 DVD Micro Theater System Theater System Logo
115 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
