Question about Argus QuickClix 5150 Digital Camera
Picture white pictures taken inside are great, but when picture taken outside the picture takes white. When looking at picture before you take it it is fine, but after picture is taken you got to look at pic to see how it turns out it is white.
  • qudah1 Jan 06, 2009
    pictures taken outside is totally white, video is Ok outside.
    I've looked inside the lense, the shutter is loos ( not attached to anyting to close it )
    I don't know how to fix it . can anyone show mw how ?
    Thanks
  • 446 Answers
It could be from the erratic flash of light, against the sun, you can try focusing.
also turn the flash to auto mode.
dont forget to rate this pls
Posted on Aug 30, 2008
I installed the small disc in my compaq presario and cannot figure out how to review what is said on the disc. also, tried calling the number, that came with the camera and the website with no luck at all. The recording said the number was disconnected.
I can't figure out how to get the camera to take pictures, the lens will not open up.
In my opinion, this is a poor way to promote your product and would not recommend this to any one!
Posted on Nov 05, 2008
White pictures when taken outside
The lens has suffered impact and the shutter or aperature blades have been damaged and are jamming. The camera needs repair / replacement parts.
Jun 01, 2010 | Olympus X-775 Digital Camera
White pictures when taking outside
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Olympus FE-220 Digital Camera
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
Picture is white
Don't know your specific camera, but it sounds like you have it set on manual (does it have P, A, S, M settings?) with a long shutter speed. This would let in a lot of light outside, and make all of your pictures blurry.
Change your setting to P (program) or Auto (automatic) and see if that helps.
Mar 18, 2009 | BenQ DC E53 Digital Camera
Outside pictures turn white
Check the white balance. This should be under menu. When you are outside in sunlight, change is to the sun icon, ect.
Are the exposures very long? If they are, they need to be shorter in high light, and longer in lowlight situations.
Jun 20, 2008 | Samsung Digimax D53 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
Pictures are all white when using the flash
it seems that the shutter of your camera is having a problem with. normally whin it gets stucked fully open it creats such problem. you need a help of a repairer.
Nov 03, 2006 | Fuji FinePix S5100 Digital Camera
Argus QuickClix 5150 Digital Camera Logo
110 people viewed this question
Top Argus Cameras Experts
Computer Links
Philip
Level 1 Expert
Are you an Argus Camera Expert? Answer questions, earn points and help others
