Computers & Internet Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i clean plastic fans by rinsing - Dell Optiplex GX280 (99301) Motherboard
joecoolvette
Level 3:
  • Dell Master 5,660 Answers
  • Posted on Jul 26, 2011
joecoolvette
Dell Master
Level 3:
Answers
5660
Questions
0
Helped
2192946
Points
18014
Pertaining in relation to a personal computer;
If the fan blade is removed from the Fan Assembly, yes, and no.
The fan motor cannot get wet.
It takes soap to actually remove dust, dirt, etc.
Otherwise I would advise using Q-tips to disturb the 'crust', and follow with a can of compressed air for computers.
(The outer layer of dirt, dust, etc., that has built up is a 'Crust'. The Q-tips break this 'crust', and allow the compressed air to remove it, and the softer layer underneath)
Then if you wish you can follow with Q-tips dipped in Isopropyl Alcohol, and use compressed air again.
91 percent is best, (91 percent alcohol, 9 percent water), but 70 percent will do. I don't use 50 percent.
The alcohol, (And water), will evaporate after you are finished cleaning.
CAUTION!
Isopropyl Alcohol (Rubbing alcohol) is EXTREMELY FLAMMABLE!
Use in a Well ventilated area, with NO sparks or flames present!
For additional questions please post in a Comment.
Regards,
joecoolvette
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
3702
Points
50
You have a couple options but an alchohol based cleaner would be your best choice since it will evaporate. Stay clear of anything with added fragrances though. They might leave a residue. They make a product specifically for washing electronic components called Blue Shower. it iis kind of pricey though; http://www.mcmelectronics.com/product/20-2100&t=1 You can usedenatured alchohol. I've used this to clean fans that were not a standard size to get extra use out of video cards and northbirdge fans. You can actually run then submerged in the stuff but it is dangerous. It doesn't conduct eletricity so there's no danger of burning out the fan but it is flammable so I wouldn't recommend it.
Asko D5457 DISHWASHER. Dishes are clean but not dry.. Especially plastics on top eack despite long dry selected. Any ideas as to what may be occurring?
Unfortunately, plastic will not dry well if at all in this model. The only heat for drying is the residual heat left in the dishware after the hot rinse cycle. Plastics do not have enough thermal mass to hold on to the heat long enough to dry. Also, you MUST use a rinse agent in this washer. Those detergent packets with rinse aid in it is not enough. Make sure to keep the rinse aid dispenser full.
1helpful
The fan oven will not self clean any ideas
the best thing to clean an oven or anything of the sort is to use easy-off oven cleaner... Spray on and leave sit for 15 mins wipe off with dry rag (or medium- fine steel wool if needed) then rinse with wet rag, make sure to rinse all the chemicals off before using it... Also this works great on car rims getting brake dust off "spray on wait til it turns purple blueish then spray with hose." NOTICE - In either case if there are any plastic parts do a spot check on a inconspicuous spot first, because it might bleach the plastic "turn it white".......... The picture is the exact kind that i use for both my oven and rims on my car
Dec 08, 2015 • Ovens
Kenmore dryer
found this..
Step 1 Run the dryer on a regular setting for 20 minutes to soften the plastic. Scrape the plastic off with a wooden or plastic spatula or paint scraper, taking care not to damage the dryer's interior.
Step 2 Apply 1 to 2 tsp. nail polish remover to a clean cloth, and rub the plastic to dissolve it. Rub the area with a damp cloth to rinse the nail polish remover.
Step 3 impt! Mix 1 tsp. liquid laundry soap with 1 cup water. Dip a clean cloth in this solution, and rub the area again. Rinse well with a cloth dipped in clean water.
2answers
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
1helpful
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2helpful
The fan won't turn on at all.
Turn the fan to the on position and feel the motor casing. Is there any vibration at all? If not, refer to your operating manual to see if there's a fuse that can be replaced. Spare fuses are sometimes attached to the cord. Also try slightly spreading the 2 prongs that conduct electricity through the wall socket for good contact.
If you DO feel vibrating, try a maintenence cleaning and lubrication with either Graphite powder, 3 in 1 machine oil or WD40. I will take you through the steps:
1) unplug the fan
2) there will either be flip releases or notches to slightly pry loose the protective fan SCREEN blade housing. Pop this off and clean + dry it, set aside.
3) With fan blaeds exposed, look at the very center of the blades. There will be a large plastic nut that turns counter closkwise to release the fan blades. Do this, clean blades with warm soapy water. Rinse, dry and set aside.
Behind this will be another large plastic nut that releases the back side of the blade housing. This nut should turn closkwise this time. Again, clean, dry and set aside.
4) You should be down to the motor, stand and fan motor stem. Check for residue build up and clean with a Qtip. You can still remove the housing face and clean behind this if necessary. There will be several screws holding this on. Wiggle apart.
5) Lay fan on its back with the fan motor stem facing up toward the ceiling.
6) At the base of the stem, one small tap of one lubricant of your choise. No more than one quick shot WD40 or 2 drops 3 in 1 machine oil.
7) By hand, gently turn the motor stem closkwise to disburse lubricant. Wipe off any excess with a tissue.
Follow the reverse steps to reassemble. If you had latches on the face, line up the notches or the name on the face to be level at allignment. If you had to pry the face off with a flat blade screw driver, again line up the screen guard (face) and pop/squeaze it back together.
This maintence should be done twice per year to assure a long life! They are made to come apart for maintence so don't be afraid. Take pictures as you go for easy referrance. It relieves you of the tension of remembering what went where! Hope this was helpful!
2answers
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
3helpful
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
4helpful
Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
Dishwasher sending out bubbles
There is a plastic strip that runs between the lower panel and the upper panel you can pull the strip off then take the outer panel and cardboard out you will see the rinse dispenser there. open the door and take the rinse cap off the dispenser and push all of the plastic tabs in at once and pop the dispenser out. now you can clean out the dispenser and put things back together.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
