Question about Sony Cyber-Shot DSC-S75 Digital Camera
DSC-S75 Charger question - input voltage?
I am living in Australia and I going to get my DSC-S75 from USA. Can you tell me if the Battery charger is accepting 110V~220V 50/60Hz? Thanks in advance..... -- Paul Juhn
    Master:
  • 551 Answers
Yes it does.
Posted on Sep 11, 2005
SOURCE:
I received a ryobi 36v battery charger as a present. It was brought in America and has a American plug. Can I use this charger in Australia
Australia has a 230v supply, and the US 110v. The power supply for your charger will indicate what input voltage it can handle. PCs, for example, typically have power supplies that can use anything between 100v and 240v, which means you can take your laptop from country to country without worrying. My Ryobi charger on the other hand says 240v input, so it doesn't have this flexibility - usually it wouldn't need to. If yours says 110v then you'll need a converter for it to function properly in Australia.
Jan 12, 2018 | Ryobi Drills
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
I live in South Africa and my son has brought back a Panasonic shaver from the USA. Can our std 220v power outlet be suitable to charge the shaver? The power pack only mentions 120v input AC?
If the power supply that came with the unit says only 120V, you must use a voltage converter with the unit. If you plug the charger into your 220V system without a convertr, it will damage the charger
Apr 17, 2011 | Health & Beauty
Have a Sony DSC-S75, digital still camera. Camera still works with a new battery, but the charger doesn't recharge the battery anymore. Any fixes to this?
Hello
The charger might gone bad too, check the charger as well, it is quite possible that your old battery was also not dead. the charger could not charge it properly,
Hope it helps
Dec 21, 2010 | Cameras
I need a charger not the battery . the charger to
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=RJrVzlsWIXw2lQjto_2vY0C
Jul 14, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
Battery charger
If there is no option of voltage change you need to buy a new one for us. because the US use 110/60 HZ and UK use 220/50Hz. S the problem not only the different voltage it is also the problem of Freequency(50Hz & 60Hz).
Feb 11, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Help w/ Sony DSC-S75
If this is your original battery, I believe that it is time to replace it. I had the same battery in my old S85, then my old 707. It finally wore out, with very similar symptoms. Go on Ebay and find an OEM replacement. Don't buy an aftermarket battery for your S75. Buy cheap, buy twice. That S75 is still a great digicam. Replace the battery and continue to enjoy it.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Replacment Battery Charger for DSC-S75?
my S85 uses a AC-L10B power adapter. (pretty sure my F717 does too) I've never seen it for sale so you might have to contact sony directly. Alternatively you can buy a dedicated battery charger instead.
Sony Cyber-Shot DSC-S75 Digital Camera Logo
73 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
