Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Tv won't turn on, power button flashing - Sony PFM-42B1 42 in. HD-Ready Plasma Television
This is not a projection TV
Posted on Aug 30, 2008
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Sony bravia kdl-32bx300 wont turn on
Mar 14, 2016 | Televison & Video
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Tv won;t turn on little green light flashes on power button
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Televison & Video
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
