Apex Digital AD-1200 DVD Player
Problem for Apex Digital AD-1200 DVD Player
Apex ad-1201 multiregion reprogramming question
By jornk on Aug 31, 2008
I have a number of region 2 dvd's and would like find the code to reprogram my ad1201.I have not been able to find the hacking site for the data on the internet.Your help or site source would be greatly appreciated.                      jornk@comcast.net
Comments:
Aug 31, 2008
- Attempted solution #1 from Benimur never saw region code on TV what is unique for the ad1201 vice ad1200
Sep 04, 2008
- I have tried both solutions as proposed with no success.I hope the experts realize that we aare working with a ad-1201 vice ad-1200.None of the suggested displays have appeared on the the screen after the suggested entries,Which makes me believe that apex used
different firmware for the ad-1201.Need more help.
jornk@comcast.net
Sep 04, 2008
- To bad your solutions were unsuccessful but you tried hard.To take the box to a service center will cost me more than buying a multi region dvd player from amazon.
Best Solution
posted on Sep 04, 2008
Very Helpful)
techexpert12
Rank: Wiz
Rating: 73%, 54 votes
take it to the service center it will be little bit costly but they will also decode the unit permanently.so no problem in the future.just once for all.
pls do rate the solution
thanks.
regards.
fixya expert team
Rating Locked! (?) jornk has rated this solution as Very Helpful
Solution #2
posted on Aug 31, 2008
Somewhat Helpful)
Benimur
Rank: Guru
Rating: 88%, 3824 votes
An possible alternative for region free setting of an Apex AD-1200:
  • Open the Disc tray and leave it open
  • Next punch in 8 4 2 1 on the remote.
  • now you see Region code put it to "ALL REGIONS" by pressing "ENTER" not "9".
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Comments:
Aug 31, 2008
- Hi again,
Appreciate the feedback.
As far as I can gather, the 1201 has a slightly different firmware on the same chassis of an AD-1200. coolguy008 has posted a link here that details the two different versions of the same AD-1200. He was kind enough to post the first probable region free code, my posting was a probable alternative both from the same source here. Since the alternative did not address your concern, perhaps coolguy008's posted method might just do the trick.
Cheers.
Solution #3
Not Rated)
coolguy008
Rank: Wiz
Rating: 83%, 602 votes
Open tray
press 8 4 2 1 (you will see -'s appear top left of screen)
Menu appears for region and Macrovision
Use up/down keys to select Region/Macrovision
Use Enter to change region/Macrovision on/off
A PAL region 2 disk played fine when switched to region 9 (Really region 0 , ie region-free)
Have not yet tested Macrovision
Comments:
Aug 31, 2008
- For more details for the region code unlock click on the below link:
http://www.nerd-out.com/darrenk/AD1200/AD1200.htm
Solution #4
Somewhat Helpful)
marked
Rank: Guru
Rating: 86%, 963 votes
Try this on:
Open tray and press 8 4 2 1 (you will see -'s appear top left of screen) Menu appears for region and Macrovision, Use up/down keys to select Region/Macrovision. Use Enter to change region to 9/Macrovision on/off.
Hope that helps........
Popular Solutions for Apex Digital AD-1200 DVD
Questions and Unsolved Problems for Apex Digital AD-1200 DVD
Do you recommend Apex Digital AD-1200 DVD Player?
Answer
Answer
Apex ad-1200 will not play dvd but will play cd. Tried the 8421 but nothing happens
Answer
The door keeps opening. hard to get it to even start up. Then once started the door often opens up... (More)
Answer
how can i program my apex ad 1200 dvd player to my ge universal remote
Answer
why will certain dvds work and other wont? it just opens back up and fires out the disk
Answer
my AD1200 DVD player says NO DISK but will play mp-3,jepg.&cd.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
