Question about Roxio Easy CD & DVD Burning
I tried what you suggested.....
I closed all programs except McAfee. Recording froze at 1% again. I check Ctrl, ALT, Delete and looked at CPU usage. It was only at 2%. Is is possible that I need to update the driver?
  • 258 Answers
It means the program is not responding try adjusting the write speed before burning 'coz sometimes if you put that in maximum speed it can cause buffer underrun errors or check the disc you are using
thanks for posting:)
Posted on Sep 20, 2008
Desktop keeps looping
try ctrl and alt buttons together and tap delete, this will bring up the running systems/cpu usage. look for anything that is not a well known program and stop it running. It is going to take some time to find what is causing it to loop but you will then be able to delete the offending program. Or buy a decent virus/Trojan program.
Apr 09, 2014 | ASUS Computers & Internet
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
on Feb 16, 2011 | Computers & Internet
What can I do about cpu reading 100%
Check what programs are taking up the most CPU resources, i.e. invoke the Windows Task Manager (use Ctrl + Shift + Escape or Ctrl + Alt + Delete, or simply right click on the Task Bar and select the option).
Look on the Processes page tab and click on the CPU column heading to order the usage by the maximum to minimum, then watch to see what is taking the most resources.
Jan 16, 2012 | Computers & Internet
High cpu useage
Open the Windows Task Manager - you should be able to right-click on the bottom task bar to do this or else, you can use Ctrl + Alt + Delete keys to invoke it too.
In the Task Manager window, select the Process page tab, then click on the CPU column header and sort the list of running processes by the amount of CPU being used - this should help you understand what is consuming high CPU on your computer.
Jan 03, 2012 | Compaq Computers & Internet
Memory full while i'm browsing
before this happens open task manager (press ctrl alt delete simultaneously).
under performance tab see cpu usage and memory.
cpu usage should be about 2% normally.
memory should not be full.
if cpu usage seems high then a virus is trying this act or you have unwanted programs which you my end from startup.
second case is of some problem in ram
Jun 17, 2011 | Computers & Internet
How to resolve a CPU 97% full problem?
Do you really mean CPU full? Where are you seeing this? In task manager?
If you mean hard drive, rather than CPU, then you need to delete some data files or buy a bigger drive.
The CPU capacity is used when the device is actually processing, so if you are seeing 97% usage when you are not performing and tasks then you have a rogue program or a virus.
Post here again if you would like me to provide diagnostic help.
Apr 10, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
Outlook express freezes up frequently when you click on a link
Use ctrl-alt-delete to also moniter the Cpu usage & processes tap for hungury system files. Have this open when you start outlook express if your cpu is running at 100% it will lock up this is probably whats happening
Jan 24, 2009 | Microsoft Windows XP Home Edition
Stays at 100% Cpu usage, I have E machine W3307
there's a good chance you have a trijan, assuming you have an antivirs programme, run it in safe mode (F8 on startup and enter using safe mode), use the administrator account to log into windows, and then go to my computer icon, right click>properties>system restore tab, then turn off system restore.(viruses and trojans have a back up in system restore)
Run anti virus programme, restart pc then turn system restore back on
If you don't have an anti virus/spyware you can get a free download with free updates here, (choose the avg free download)
Sep 09, 2008 | E-Machines Computers & Internet
Cpu overclocking
Try this. press ctrl-alt-delete to view your task manager. Click the processes tab. From the list of items, look at CPU and Mem Usage to see what all is running.
Apr 04, 2008 | Intel Motherboard
Sound clarity
CTRL + ALT + Delete to open the task manager. Go to processes and close some programs that aren't needed.
Sep 21, 2006 | Image Line FL Studio 5 Producer Edition
Roxio Easy CD & DVD Burning Logo
29 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
