SOURCE: what engine will fit in a 1986 ninja?
Get a different engine just like the one you had. Google " motorcycle salvage Kawasaki " and you can probably find the engine you need there. The best thing is now you have a whole lot of spare parts > the old engine.
Please rate this answer. Thanks Andre!
SOURCE: ninja zx6 headlight problem
Check the head switch to begin with,if thts ok thn proceed to check the head light wiring from the bulb backwards to the switch, there may be somewhere or by the connectors tht it has fallen lose.
Hope this helps!
SOURCE: starter solenoid for a 1996 ninja
Go to http://www.carlsalter.com/motorcycle-manuals.asp , for a freebie manual. My advice is you would be far better taking it to an auto-electrician for the electrical work, but you should be able to take the starter out and replace it yourself. Starters are complex, and have it fully checked out first, the problem could be the battery or even the alternator is not charging properly.
SOURCE: why my 2001 kawasaki ninja
Just a thought, if you are running ethanol fuel it will lower the bikes idle speed. If you run no ethanol fuel your idle speed will go up. Turn your idle screw to raise the idle . Hopefully , your problem is just that simple.
SOURCE: i have a 1993 kawasaki
You need to check the pipes for leaks or if its the gas tank itself you need to weld it(let it dry for at least a week) check the fuse for the gauge or trace the wiring.
