Question about Sport & Outdoor - Others
Suzuki atv we would like to see the inside of the motor to determine why bike is stuck in 3rd gear
    Problem Solver:
  • 34 Answers
This sounds likea transmition problem which is only meant to be looked at or fixed by a professional. Take the ATV to a dealer and have them take apart the transmition or do a diagnostic on the machine.
Posted on Aug 30, 2008
It's stuck in 3rd gear and idk what's wrong with it any help?
Shift dog damage to much stomping of shift level.
Mar 25, 2016 | ATVs
I got a 2005 Suzuki eiger 400 I was riding and a
its bent, stripped or broke the gears inside. not an easy repair.
Oct 12, 2014 | Suzuki 2005 Eiger Automatic 400 4X4
Bike stops accelerating in 4th gear and slows down sometimes
thats a puzzle. hope you haven't sheared the teeth on 4th gear.
Apr 21, 2014 | 2004 Suzuki VL 125 Intruder LC
Gear shift stuck in 3rd on 1991 Suzuki samuri
i think that would be ur linkage. u gotta get it up on a lift or get under it and it links ur gear shift to ur transmission. it could be on a bind or stuck from inside transmission.
Mar 11, 2013 | 2003 Mercury Mountaineer
I just started my 2006 suzuki gsxr 600 for the first time since fall and it starts fine in neutral but as soon as i put it in gear it cuts off. The kickstand is up
Sounds like your clutch is stuck on [not disengaging when you pull the leaver]This can happen over a long storage-no use period.To fix put the bike in 3rd gear and start the engine with the clutch lever pressed[caution the bike will want to surge forward so keep your foot on the brake]Make shure to have the engine up to normal running temperature before you try this fix.the engine firing along with the brake pulled will release the sticking clutch plates.This will work!!!
Mar 08, 2010 | 2006 Suzuki GSX-R 600
Not able too down shift gears from 3 too 1 on my suzuki bandit 1200 o4 plate
hello had a atv that did this, atv had set for a while, went to ride it, had all gears, went to downshift , to first, stopped then took off again, only had first gear then second no other gears, i tried everything, all different kind of oil additives, they never worked, more than likely, my atv had set for a while and the shifter fork inside the motor had rusted just a little bit, the gear had got stuck , i had to split the motor cases, to fix mine, make sure your shifter isnt stripped out, maybe it needs adjusting, i have seen people tap on the gear shifter sometimes and it would break loose, some atv mechanics, say to ride it, eventually it will come unstuck, or break the case in half to fix shifter fork and gears....
Feb 25, 2010 | 2004 Suzuki GSF 1200 Bandit S
I have a 2001 Suzuki 400 4x4 atv. It was making a whirring sound from the engine almost like a loose chain then when put it in gear it locked up it will roll around in neutral but the motor will not turn...
sounds odd your motor and tranny are seperate if it goes in neutral then the transmission is disengaed sounds internal pull the spark plug and see if it turns then maybe a vlve bent timeing chain many reasons this could happen do u have any more info
Dec 04, 2009 | 1978 Suzuki GS 400 E
3rd gear on my suzuki DR800 has dissapeared - help
3rd gear has been destroyed probally tore the gears up on it.it not as difficult as your mecanic says.tare the gear box cover off and look inside check for shavings [metal] .or anything that doesnt look rite. could be as simple as a sheard pin.
Jun 26, 2009 | 1992 Suzuki DR 800 S
Tried to pop start in 3rd gear kfx450r atv engine will not turn
kfx 450 is fuel injected
needs good battery to start
not enough info to diog
does the starter turn over
is it getting spark
or is fuel pump working
need more info
Dec 18, 2008 | kawasaki Full Suspension Mountain Bike Men
Sport & Outdoor - Others Logo
176 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
