Question about 3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk)
Cnt open the config pge
Well i forgot the password of my 11g router and i resetted it and now i m not able to acces its configuration page no matter what i have tried the ips 192.168.1.1 and 192.168.1.2 192.168.0.1 and many more but it just wont show so what should be done
  • prince_lupin Dec 14, 2008
    i cant open my config page!!
    Problem Solver:
  • 8 Answers
Go to live assistance at linksys.com
Posted on Aug 30, 2008
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Jun 24, 2012 | D-Link Computers & Internet
I am trying to install/configure buffalo airstation wifi device. My OS is windows vista. I cannot detect this device WLI3-TX1-G54 thru wirless LAN. Also i successfully installed CD which comes with it. Can...
  1. After unpacking your Buffalo wireless router, connect the ethernet cable from your jack to the rightmost ethernet port on the back of the router. This is the blue WAN port labeled "Internet". Next, use another ethernet cable to connect your computer to the router, using any of the 4 remaining open ethernet ports on the back. Finally, plug the AC adapter into the power port on the router and plug it into the wall.
  2. Once the router has been plugged into the network and powered on, the power light will come on and the other status lights on the front will go through a series of flashes. Once the leftmost diagnostic light labeled "Diag" has gone off and the light labeled "Router" has come on, this means your router has been initialized and is connected to the network.
  3. Now open a web browser window and enter 192.168.11.1 in the URL field and press enter. You will get a prompt to enter a username and password to access your router settings. You should enter "root" (without quotes) as the username and leave the password field blank, then click OK. You are now taken to a page where you can configure your Buffalo wireless router.
  4. Click on the Admin Config button on the top right of this page. Enter a name for your AirStation and click Apply. Wait for the router to restart with the new setting, you may have to refresh your browser window.
  5. Next click on the Password button in the small row of choices under Admin Config. The Administrator name is fixed as "root" however, you should now choose an Administrator Password (8 characters or less) and enter it in the two fields provided, then click Apply. Wait for the router to restart, and you will be prompted to login with the username "root" and the new password you just set up. If you choose a password over 8 characters long, you will be unable to login and will have to reset your wireless router by using the pinhole on the bottom.
  6. Next click on the Wireless Config button on the top, third from left. In the small row of choices under Wireless Config, click Basic(11g). Make sure the box labeled Enable next to the Wireless Radio setting is checked. For the SSID setting, switch to the second choice Use: and then choose a name for your wireless network. You should write this name down and keep it near your wireless router in case you forget it. Click Apply.
  7. Next click on the Security(11g) choice under Wireless Config along the top of the page. For the Wireless Authentication setting, select WPA/WPA2 mixedmode - PSK. For the WPA-PSK (Pre-Shared Key) field, choose a password that is between 8 and 63 characters (letters and numbers only) and enter it here. Click Apply. buffalo04.jpg
  8. Your Buffalo wireless router will restart and is now configured to connect securely to the Internet.
Dec 05, 2011 | Buffalo Technology Computers & Internet
I forgot my password and cant get on the internet how do i fix
If you can remember your password,reset the linksys router.
Resetting the router to the factory defaults will delete any changes you have made to the router, including any security settings.
To reset the router using the reset button, use these steps:
1.Look for the red reset button at the back of the router.
2.Press and hold the reset button for approximately 5 seconds.
To acces the router configuration panel -open your browser(Internet Explore,Firefox..)
Type http://192.168.1.1 to acces your pages. Enter user name and password,leave user name blank and enter admin as the password.
Good Luck!
Jan 21, 2011 | Linksys WRT160N Wireless Router
I forgot my password ??
you can find it by going into the administrator/router configuration web page and under the wireless section you may be able to find it!
the config page is usually found by typing in your internet browser 192.160.0.1 then press enter, then when asked to enter user name and password, leave user name blank and password enter "admin"
if you can't access the configuration page because you also set a different password or user name that you can't remember the only option is to reset the unit to defaults pressing for 30 secs a reset button usually found on the back of your router while your router is powered.
some new linksys routers I have encounter may require a pin instead of a password, the pin is found on the bottom of the router, try that too.
I strongly suggest that if you have technical questions that you review the manual for your unit that can be found here on the download section and come back if you have further questions after reading the manual
Apr 19, 2010 | Linksys WRT160N Wireless Router
I forgot password of my linksys rv042 vpn router how can i recover it without resting the router becoz they have a some special configuration on this. thanks gil
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may may have no choice but to "Reset" the router. The button is on the back of it. Just press it and hold it
Nov 25, 2009 | Linksys RV042 VPN Router
Router problems
Hi!
The default password is admin.
Please see this link for the default settings and password for your 3com router---
Default Password
Please rate this solution
Thanks
Rylee
Feb 14, 2009 | 3Com OfficeConnect Wireless Router
How do I disable the wireless connection in DI-524 ?
Dec 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Problem with my buffalo airstation G54 WHR-HP-G54
Jun 23, 2008 | Buffalo Technology AirStation G54...
Acer router forgot password
The reset button might have to be held in for 10 seconds or more and should reset to default, but the password if you have not changed it; could be 'admin'.
Jan 12, 2007 | Acer D-Link 2.4GHz Wireless Router 802.11b...
3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) Logo
293 people viewed this question
Top 3Com Computers & Internet Experts
NBX_Tech
NBX_Tech
Level 1 Expert
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
