Question about Konica Minolta magicolor 2400 Laser Printer
Vertical white line
I just started getting a vertical white line down the page
  • zenys Sep 09, 2008
    I am also getting a vertical white line on the right side on my paper. Any idea on how to resolve?
The laser lens may be dirty. Remove the drum cartdridge and wipe the lens with a soft cloth. Manual page #55.
Posted on Oct 17, 2008
    Scholar:
  • 98 Answers
The cartridges are near to end.so refill the cartridges or replace the cartridges.
or you can also try to clean the cartridges by giving cleaning option from your pc.
hope this helps....
thanks.
Posted on Oct 13, 2008
Lg tv model cf14j50k have many thin vertical white lines on screen and have sound what the problem?
These are retrace lines. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Oct 15, 2015 | LG Televison & Video
Vertical white lines on page after printing
There will be something covering a small patch of the laser mirror. Find the laser mirror inside the machine (Normally above where the cartridge sits) and wipe this with a clean cloth. Other than taking the cartridge out there is no dissassembly required.
Dec 25, 2012 | Canon LBP 1120 Laser Printer
Why do i have white lines on my 26
Hello
The fault is with the vertical output section of the TV. The lines you see at the top side, is technically called 'vertical retrace' lines. The main cause to this fulat is with electgrolytic capcitors at the vertical output section. Repalce all the electrolytic capacitors at this section. There will be 5 or 6 numbers of them. Repalce all at the same time. This must solve the problem to your TV.
Mar 19, 2012 | iLO Televison & Video
Got a brand new Pixma 280 here. Have aligned the print head and executed cleanings, reinserted the ink etc, but still there is one area that is blurred on every printout which results in a white vertical...
The Pixma printer allows to make test pages and do maintenance on it.
First go to Start Menu on Desktop at the left bottom Click on it then go to printers and Faxes.
Right click then click on Properties. Then go to Maintenance panel Click on it. Do the Deep Cleaning, Roller Cleaning keep on doing it until it shows you paper that does not leave a vertical white gap. You have to be very patient as this does not go away quickly. You might have to run 20 pages doing this cleaning until that line is gone.
Oct 13, 2011 | Canon Office Equipment & Supplies
Unwanted line down centre of page
you need to reassemble image unit and clean completely
if you dont know how to do just bring it your printer to technicians
Jan 06, 2010 | Samsung CLP-510 Laser Printer
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
White Lines
My magicolor 2430 dl prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
jim
Jan 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
224 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
