Unable to monitor cpu temp in bios. says 65 degrees c all the time
I have an asus p5kse/epu main board. An intel quad core 9300 cpu @ 2.5 ghz.
my problem is that if I go into bios hardware monitor I have the same cpu temp all the time. 65 degrees c. I have reset cmos and updated my bios as instructed by asus. I know my system isnt running too hot but just think I need to be able to monitor temp. I have tried different programs that monitor core temps like real temp. They can read all temps correctly except core 0. Which never changes from 59. I hope you have an idea as to what the problem is. thank you for your time.
Paul
  • kingsface Apr 29, 2009
    I have a similar problem on e5200 and asus p5kpl-vm. Using real temp or core temp, one of my core temp registers 56 degrees constant whereas the other core varies every other second or so at 43. Don't know whats the issue ?
I think 59 is not to hot. perhapas is the correct temperature
mafw1
Posted on Aug 31, 2008
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
Bios problem what are new drivers bios
P5B-E Plus Uses 100% All High-quality Conductive Polymer Capacitors! - Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® Quad-core CPU Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® P965/ ICH8R
- Dual-channel DDR2 800/667/533
- Fanless Design - Stack Cool 2
- PCI-E Gb LAN/ 8-ch HD Audio
- AI NOS™ / AI Gear / AI Nap
- SATA on the Go/ 1394/ Noise Filter
  • Another option is through the Internet. Launch the utility:
Start > Programs > Asus > ASUSUpdate
Follow the directions.
There is also ASUS EZ Flash.
Make sure that you do have a copy of your current or original BIOS, if you have the CD that came with the MoBo then you are golden.
Sep 20, 2011 | ASUS P5B-E Motherboard
Hi I just bought a Intel Core 2 Quad q8400 for my gigabyte GA-G31M-S2L. It won't boot up!!! It freezes when I try to enter bios setup and if I do manage to get in, it freezes at the options screen. It...
What size power supply are you running? If you are not running a minimum of 400watt , I would anticipate issues with this type of processor. Since it is freezing right away, it could be bad memory. You can try memtest86.com to download a memory test tool to verify.
Secondly, you may want to reset the board by moving the jumper from normal mode to reset mode.
last thing, it's not impossible for a processor to be bad. Since it is an Intel processor; it should have a 3 year warranty on it. Any dealer who sells Intel should be able to warranty replace it for you.
Dec 31, 2010 | Intel Core 2 Quad Q8400 Computer System...
Intel core 2 quad q8300 EXTREME TEMPS
First off....alwys, always apply a very thin film of thermal grease to the cooler and Proc. This grease is designed to fill in the microscopic grooves and holes in the material. Do not glob it on thick, it doesn't work that way.
Case design has something to do with cooling but you are experiencing higher than normal stock temps, the more fans the better, you want some pushing air in the front and pulling it out the back, a good flow across all the hardware is essential. Installing a good processor cooler may require you to remove the motherboard so you can get to the back of the board to mount the cooler retainer plate, but there are other coolers that do not require this. If it were up to me, I would deffinately take the time and remove the motherboard and do this right. You need to get those temps down. I personally like this one....
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118003
Not too expensive and does a great job for the LGA775 socket.
For cases...I always use HAF932s...they have everything that is needed and are tool less.
May 07, 2010 | Core 2 Quad Processor Q8300 - INTEL -...
Will Intel Core 2 Quad Q9300, 2.50 GHz processor work on asus p5n73-am motherboard..is it compatible, will the motherboard crash or will the processor overheat. I am looking to change my current processor...
Motherboard info
Yes it'll work. Worst case scenario is that you will need to do a bios update. Overheat should not be a problem if you are using the intel reference cooler wich is provided with the cpu.
Mar 03, 2009 | Computers & Internet
Abit ip95 mobo
You should really check these things first or consult the motherboard documentation which lists in great detail what the board supports
Get yourself a new manual if youve lost the one that came with it
ftp://ftp.abitshop.com/pub//manual/english/ip-95.zip
And to answer your problem , no you cant have a quad core
your specification says
"CPU - LGA775 Socket for Intel Core 2 Duo/ Pentium D/ Pentium 4/ Celeron D/ Celeron Processors with 1066 MHz FSB - Supports Intel Hyper-Threading Technology "
It would say "Intel Core 2 Quad" if you could
Try powering it up and it will probably either:-
a)Overheat
b)Spark and set on fire if theres not enough cooling
c) Cause a power cut , Quad cores take more power than the boards designed to support , otherwise they would have said i t supported quad cores.
d)Fry up the motherboard , making it useless
e)Fry up the processor , making it useless
f) all of the above
Jan 07, 2009 | Ziotek ATX Motherboard Standoff, 12 Pk...
ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Jun 06, 2008 | ASUS P5VD2-MX SE Motherboard
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
