Question about Sharp Aqous LC-26D5U Television
Sharp agous .. no power
Hi .. I have lc32d43u sharp agous tv set , all at once if would not power up I have no standby light .set is completely dead
  • Dale E Sep 06, 2008
    I have a red power light but after about 30secs it turns to a red blinking light.
    I cannot get any further so no TV. I have tried the system reset button and while I hear the slight click of reset, the red blinking light problem is still there.
    My model is SHARP AQUOS LC-26GA4X
    Thank you
    Dale
  • panini Oct 24, 2008
    I have a Sharp aquos LC-37HV4U. Out of nowhere I can't get POWER. The display status indicator on the tv is blinking red. The AVC status indicator is just red. Turned off power for an hour and re-set. Still Nothing.
    I'm trying to see if there is a simple solution before I spend $170 for a company just to pick it up. Anyone???
    Thanks
I have same problem, In Caribean and repairs and new TVs are extra costly. Bringing power supply back with me to USA to see if I can buy a new one.
Posted on Apr 24, 2010
SHARP AQUOS IS GARBAGE.
I had the same problem. 2 months out of warranty and the tv power supply is dead. The repair will cost as much as a new tv.
Sharp AQUOS IS GARBAGE.
Let sharp know , maybe they can fix all of our un-powered lcd tvs.
Posted on Sep 20, 2009
Needs power supply unit, Part# for Sharp MODEL LC-32D43U, RDENCA198WJQZ or DPS-178AP A Try to purchase from Sharp or check the internet, cost should be under a $100.00
Posted on Nov 10, 2008
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
My tv cuts on but flashes red light 5 times and shuts off
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
24inch Bush smart TV/DVD not working.
Could be an open internal fuse or power supply failure
Jan 09, 2017 | Bush Televison & Video
I have a lg tv 60 inch tv ln5600 when powering on red stand by light blinks 3 time then no light pic or sound not backlight and no image when using flashlight treid replacing power board does same
Jan 08, 2017 | LG Televison & Video
Can't switch off tv
All tvs draw a current so long as they're plugged in, this is what allows a remote device to power them on. Modern tvs will generally have a light to designate this (I think this is what you're referring to as standby). The only way to cut the current to your tv would be to unplug it or if it's connected to a surge protector, switch that off.
Jun 28, 2014 | Televison & Video
How to disable mode from lg 55 inch smart tv 55ln5750
You missed the word demo, why repost?
On remote Press SMART (with house symbol)
go to
settings then
option then
mode setting then select
home use
(and, if you're feeling really brave, but it's not necessary to do this to remove demo mode
to return to initial settings
SMART
Settings
OPTION
Initial Setting
Deletes all optional settings and returns to initial default mode.
Once initialization is complete, the TV will turn off and on by itself.
If Lock System is activated, a pop-up password prompt will appear.
Do not turn off the power during initialization)
Jun 27, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
Sharp Aqous LC-26D5U Television Logo
4,495 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
