Question about Dishwashers
The drainage hose is to short to fit into the waste pipe
  • 706 Answers
Go to Home Depot or Lowes or any large home improvement store and they have extension hoses with fittings for this application...
Posted on Aug 31, 2008
DRAINAGE IS CLOGGED
There is no part number for the drain. find a piece of copper tube that fits inside the hose and ease it up inside the broken drain hole but only a short way. Silicon seal around underneath it
Apr 19, 2012 | Kenmore Freezers
Error code E 18
make sure there is nothing stuck in the imp[eller, which is the pump at the front bottom of machine. ( make sure it turns freely ) also try draining the machine by way of drain hose in a bucket. if it drains this way ok then fault is waste pipe plumbing blockage. hope this helps
Jan 02, 2012 | Bosch Washing Machines
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine. Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor. pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards. If the pump is too old or worn out then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
Need to remove drainage pipe, can't remove white plastic clip, is there a knack?
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any  foreign objects. The pump is usually at the back right side ( looking at the washer from the front ).
May 07, 2009 | Hotpoint WF430 Front Load Washer
E-20 after washer is filled , how do I fix it?
check your drainage,,,check for kinked hose ,,check for clogged waste pipe,,last check pump...onthejob
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Dishwasher
you can buy the drainage hose ( B&Q) by the per / m if you can not install a drainage pipe closer.
May 30, 2008 | Hotpoint 24 in. FDW60 Free-standing...
The washing machine is sending the waste water into the sink
the drainage pipe under the sink is clogged so when machine releases the waste water it goes in the drain slowly so it come up in the sink you have to clean that drainage pipe under the sink
May 05, 2008 | Washing Machines
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Waste water problem
you have a blokage in the water drainage
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Dishwashers Logo
184 people viewed this question
Top Dishwashers Experts
