Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Bissell ready tool dial broken
As my subject line says my dial is broken how do I get a replacement and a guide to remove and replace it myself?
Thanks.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sghs
Posted on Sep 30, 2010
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
Oct 27, 2011 | Bissell 1770 Quicksteamer II Upright...
How do you get the smart mix dial to line back up when replacing the top plastic cover on a bissell pro heat pet.
First, insert the black plastic control valve all the way into the hole. Make sure that the rounded face with the cut in it is facing toward the tall part of the chamber/hole where you inserted the valve. Try to line up the dial with where the threads would enter the cut in the valve. Hint: the hole in the center of the dial will go over the tall part of the chamber wall. Once you believe you have it aligned correctly, replace the plastic body cover and keep the dial out of the body cover. Just put in the screw on the side the dial is on, so if it is not aligned properly, you can remove the cover more quickly. Once you have the body screwed down, screw the dial into the hole and it should align easily with the valve in the hole. If not, remove the body cover, and try to realign the valve again. Repeat until you get the dial to screw in easliy.
I just did this today because I had to fix a customer's unit. It took me about 20 minutes or so to figure it out, but I finally got it. I was hoping your question had an answer to it when I got on here, but at least I got it figured out anyway. Hope this helps! That is if you still have this unit...
Jan 26, 2011 | Bissell 8910 ProHeat Clear View Upright...
How do i get the hand tools to work
Turn the dial on top of the water tank to TOOLS this will divert the suction from the floor to the tools.
Follow the link below for a copy of the User's Guide.
http://www.bissell.com/user-guides/?searchtext=9200&searchType=search&mode=228&pagesize=25
Aug 11, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Bissell Pro heat Carpet cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you work it?
below is a website to retreive a free manual for yours. have the model number ready so you can find it much easier....
bye.
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_vacuum_cleaner_product_list.html
Feb 07, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Is it easy to replace the debris door myself on the vacuum? Mine broke and I want to replace it myself but not sure if its easy or not.
Take a close look at the old debris door and determine whether or not you have the tools necessary to do the job. If you do, remove the old one. The new one will go one in exactly the opposite steps.
Sep 30, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Broken Smart Mix Dial-How to replace
You will have to remove the top, the knob screws on but has a stop tab. Is the plastic below the knob ok, if not then you need to replace the top cover. After you replace the knob, then put the piston on from underneath, have it set to water only selection, then put the top cover back on.
Mar 04, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
1,508 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
