Question about Pioneer AVH-P6500DVD Car DVD Player
Power will not turn on
When i start the car up monitor comes out but the power to the radio does not come on i changed the face plate and the hideaway unit so i know problem is in the radio what could cause the power not to come on
Did you ever find out what the problem was???
Posted on Nov 17, 2009
I just sent the radio to pioneer still waiting
Posted on Sep 02, 2008
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
Need a hideaway unit for a kenwood kvt819dvd
i have one.they jacked up my monitor but i still have hideaway and all wires!! texashustla89@yahoo.com thats my email hit me up
May 20, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
Hideaway brain unit on my kenwood KVT-617 doesn't work
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
timsterp99999@att.net
May 29, 2009 | Kenwood KVT-617DVD Car DVD Player
Power comes on but nothing works even monitor
It's probably your ribbon cable is broken. Pioneer replace it for free the 1st time. Contact them to send it in for service. It is a common issue for the Avic N series. If it is out of warranty then the guy on Ebay will fix it for you for around $100. Try SAME DAY AUDIO SERVICE, his name is Rick and he is very reliable. Goodluck.
Nov 22, 2008 | Pioneer AVIC-N1 Car DVD Player
IC Power 19'' LCD Product PA192D Model # 900G quit working
I C Power PA192D Model 900G, Mfg Sep '05 19inch LCD
I purchased this monitor at Goodwill not working for $20. The 900G power light failed to come on and there was no video when turned on. To fix, first pull the 2 screws at the bottom of the back side of the monitor_ note this face is NOT removed by prying with a screwdriver like other monitors, it IS removed by sliding the face plate Upwards. Remove the LCD screws and remove the wires to the backlights carefully noting what goes where. Remove the metal cover and remove the 110volt power board. I found smoke trails under the cover and a swollen 470uf25v capacitor number C206, and replaced C110, C211 all were 470uf. Reassembled and found no change. Tore down again, used the ESR meter CapAnalyzer 88a and found C114 47uf25v to be 30% working, the volt ohm showed the cap to be good, that's why the ESR meter was needed. Replaced the 47uf25v C114, tested the large 100uf 450v capacitor, it tested only slightly under spec , could not find a 100uf at Radio Shack so did not replace it. So in this attempt the only thing changed was the 47uf C114. Reassembled and now works perfectly.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Nov 20, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
Eonon 837 car multimedia.
IF THE RESET FUNCTION DOESN'T WORK, USUALLY A LITTLE PIN JOLE SOME WHERE ON OR UNDER THE FACE PLATE, USE A PAPER CLIP TO TRY AND RESET, IF THIS DOESN'T WORK RETURN THE UNIT WHERE U BROUGHT IT IT MAY BE A MANUFACTURE DEFECT
Aug 21, 2008 | Car Audio & Video
DEH-P9600MP not working
make sure our face plate goes in good snap in take a q-tip clean contact from radio to face plate hope its that cheers
Jan 19, 2008 | Pioneer DEH-P9600MP CD Player
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
179 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
