Question about Palm Tungsten E Handheld
How to change the default handler from Outlook to Palm desktop?
When i originally set this up on my computer i used MS Outlook but now would like to switch to Palm desktop. Is there a way to get all my info onto the Palm desktop? I can't seem to syc and get the info on my palm to go to the palm desktop program. Please help! Thanks!! =)
    Master:
  • 473 Answers
Change sync methods from outlook to palm desktop !!!!! Hi, There are two ways to change the sync methods : 1. Insert the installiation disc into the cd rom device , u will get a window called dicover ur handheld , there please check for change ur sync methods , and u will get another window sayin ur currently using microsoft outlook to sync , would u like to change to palm desktop , say yes and then u will get congrats , click on finish . To make sure it is changed from outlook to palm desktop , right click on hotsync manager at the bottom right corner of the pc , make sure only local usb has a check mark and then left click on custom , in custom check and see if u see calender [outlook] or just calender , if u just see calender , then presuming all the data is in handheld , highlight calender click on change and change the action to handheld overwrites desktop then click on ok , do the same for contact , tasks and memo then click on done and perform a hotsync. 2. Insert the disc , open up my computer , then u will see ur cd rom drive , right click on it and left click on explore , u will find yellow folders , please check for a yellow folder called post install , open that up and inside that u will find outlook switcher , left double click on it and follow the same procedure as told in the first step . Regards
Posted on Sep 11, 2005
Switching to the MS Outlook Conduits using the Palm Installation CD
Search Installation Disk, I had this same issue. The Outlook conduit is on the installation guide, you have to search for it. 1. Insert the installation disk. 2. Open My Computer 3. Right click the drive that contains the disk. 4. Click Search. 5. Enter the conduit name for your device (ex: Pocket Mirror) 6. The search results should contain the executible file that you need to run to sync with Outlook. Hope this helps.
Sep 13, 2005 | Palm Tungsten C Handheld
Calendar Not Syncing
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
Sep 12, 2005 | Palm Treo 650 Handheld
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Sync with outlook
Change ur sync method. To change the sync from palm desktop to outlook , insert the installiation disc in and then install the pocket mirror conduits conduits that will help u to sync with outlook .
Sep 11, 2005 | Palm m125 Handheld
Can't synch Outlook Calendar Appointments
Try uninstalling with Windows Uninstall Clean-up tool. XP seems to do a poor job of installing conduits sometimes. I think this might be an issue with the one conduit no being registered correctly in the Windows Registry. You can get this tool here: http://support.microsoft.com/default.aspx?kbid=290301 Uninstall Palm Desktop. Then shut down the PC. Then start it up again and re-install Palm Desktop. I hope this helps.
Sep 11, 2005 | Palm Zire 31 Handheld
No synchronization when Outlook express is default mail program
Email synch is based on current MAPI preferences. The problem you have is that the VersaMail conduit assumes your mail client must be the MAPI default email client. You could adopt another profile in Outlook instead of OExpress which picks up the account you use in OE. This is the first instance of this problem I have ever heard of so I doubt if PalmOne would make a software change on this.
Sep 11, 2005 | Palm Tungsten E Handheld
How do I NOT HotSync with Outlook?
Insert the installation CD and select Change your synchronization method. If that doesn't work, or the option is not available, in Windows, click Start>Run then D:\English\PostInstall\OutlookSwitcher.exe /palm (where D: is your CD drive AND your install CD is inserted; also check to make sure the file is at that location).
How do I switch from HotSync with Palm Desktop to HotSync with Outlook?
I have a T5 and assume it's the same, but try putting your software install disk in your new PC at work. One of the options is to change sync with Palm Desktop and Outlook.
Sep 11, 2005 | Palm m505 Handheld
Zire 72 and Outlook 2003 - I think I've tried it all! Doesn't work....
you don't need pocketmirror for zire 72 because palm desktop have outlook conduits to handle outlook synching. inorder for you to sync using outlook you must have the outlook conduits installed which seems you have it already installed. you have to disable some older conduits inorder to avoid conflicts with the conduits. to do these follow these steps: 1. right click on the hotsync manager icon on your system tray 2. click on Custom... 3. select Date Book (Outlook) 4. click on Change... 5. select Do Nothing and set it to default 6. click Ok 7. repeats steps 3-6 for Address Book (Outlook), To Do List (Outlook) and Memo Pad (Outlook)
Sep 07, 2005 | Palm Zire 72 Handheld
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit www.PocketMirror.com for more information about Chapura(R) PocketMirror.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm Tungsten E Handheld Logo
188 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
