Question about Brother CS-8060 Computerized Sewing Machine
Presser feet for CS-8060
Will the SA187 Open Toe Quilting Foot & the SA188 Open Toe Walking Foot work on a CS-8060 machine? If those worn't work, would the Universal open toe feet work?
I have the closed toe feet for my machine and have a very difficult time seeing where I'm sewing with those.
5 Suggested Answers
SOURCE: stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Posted on Sep 23, 2008
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
6ylucy
  • 742 Answers
SOURCE: I have misplace my manual for my yamata sewing
ask at manualfox.com
They have it.
Posted on Feb 02, 2010
  • 1788 Answers
SOURCE: Uneven stitches while machine quilting.
Are you using the right size needle and thread? Also, check tension recommended by your manual. Let me know if that helps, because I can ask my sister who has that machine
Posted on Jul 26, 2010
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
Does the singer 533 have either a walking foot, a patchwork foot, or a quilting foot
You should be able to find some, if not all, of the presser feet you mention. You just need to determine what shank your machine has and make sure the presser feet you purchase have that same shank. (You may even have a snap-on adapter for your machine, so you just need to order the snap-on feet you want.)
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Singer 533 Stylist Parts
Free Motion Quilting Foot for ALL SINGER KENMORE
Apr 19, 2017 | Singer Sewing Machines
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Apr 05, 2017 | PfaFF Sewing Machines
E99670 short shank, or snap on presser feet?
Make sure--Does the machine take a short shank presser foot? If so, you can replace it with a short shank zig-zag presser foot. You can probably go to a regular sewing machine repair shop and find a replacement presser foot.
**NOTE--the links below are examples of what is available. I cannot vouch for these vendors as I've never purchased from them. Do your own due diligence before purchasing!!!
Here's an open toe presser foot:
Open Toe embroidery satin stitch foot Low Short Shank Babylock Bro White...
or a regular zig-zag foot:
http://www.ebay.com/itm/Vintage-ZIGZAG-FOOT-Fits-Singer-Pffaff-Other-Mfrs-Low-Short-Shank-Apps-MPN-C24-/401237995786?hash=item5d6ba5f10a:g:8UcAAOSweWVXcubS
OR you can buy a short shank adapter and a kit of snap-on presser feet that will give you a big variety of different kinds of presser feet, probably including a zipper foot, hemmer foot, 1/4" quilting foot, darning foot, teflon foot, etc....(probably more than she will ever use!) The snap-on kits are available online, try eBay or some of the other sites. They most likely are not Singer brand, but are most likely generic. However, if your granddaughter is just learning, this may be the broadest variety of choices.
These are examples of snap-on presser feet available.
Snap-on Adapter example (most kits do not include the adapter):
http://www.ebay.com/itm/Low-Shank-Presser-Foot-Holder-Adapter-Snap-on-Singer-Kenmore-Juki-Elna-Janome-/222013366993?hash=item33b10722d1:g:Sa0AAOSwJb9WsRpp
Snap-on kits- examples:
42 PCS Domestic Sewing Machine Foot Feet Snap On For Brother Singer Set...
http://www.ebay.com/itm/1-Set-32-Pcs-Domestic-Sewing-Machine-Foot-Feet-Snap-On-For-Brother-Singer-Janome-/282017920492?hash=item41a993f5ec:g:MrAAAOSwMVFXH3rP
Dec 10, 2016 | Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
I love free motion sewing but I have two totally different sets of instructions! One says use a walker foot, one says no foot! Please tell me every setting/foot. I am breaking alot of needles and getting a...
Ok, I hope I can help.
Quilting with a walking foot is technically (IMHO) not free motion quilting. With a walking foot, the feed dogs are still activated so they can work in conjunction with the walking foot to (hopefully) prevent wrinkles in the fabric sandwich. Quilting with a walking foot is more suited for stitching in straight lines or stitching in the ditch. In this mode, you would not pull or push the fabric as the machine should do that.
FMQ Free Motion Quilting requires the operator to manually move the fabric sandwich under the needle. There are some sewists who do not use a presser foot, however, if you value your fingers, it would be best to use, at a minimum, a darning foot. Darning feet and free motion quilting feet are shorter than a regular presser foot so it does not make contact with the feed dogs or the needle plate. The space between the needle plate and darning foot is what allows a sewist to maneuver the fabric. Usually, the feed dogs are lowered when performing FMQ, but there are some sewists who don't. It's probably a matter of preference.
Most older sewing machines included a darning foot in the accessory kit. Newer sewing machines may have several presser foot options for FMQ. In addition, there are many FMQ presser feet available on the market that can be ordered to fit your specific machine, ie Big Foot.
There are a wide variety of FMQ presser feet, some have springs so they "hop" on the fabric, some are metal, others are clear plastic, some are full circles, others are not round or may be open toe. There are also special presser feet that have a thicker base made for FMQ with rulers--the thicker base helps prevent the ruler from slipping under the presser foot and being struck by the needle.
In addition to the multitude of FMQ presser foot choices, there are a variety of other tools available, ie quilting gloves, quilting hoops, marking tools, pattern transfer supplies, silicone mat that covers the sewing machine surface making it easier to glide the fabric.
Amazon com Queen Size Supreme Slider Free Motion Machine Quilting Mat...
Free Motion Quilting for Beginners
There are tons of tutorials for FMQ. Just as there are many different methods, the right method is the one that works best for you. There are also lots of rules, but rules are made to be broken, so don't let someone else squelch your creativity. Quilt to please yourself.
Above all, PRACTICE, PRACTICE, PRACTICE. I have a small whiteboard that I practice drawing designs. Muscle memory will make FMQ easier. There is also the need to get a comfortable sewing speed along with the speed at which you move the fabric. If you are breaking needles, your fabric movement is probably too fast for the sewing speed. Also, practice moving the fabric while keeping the sewing speed consistent.
Good luck! Remember, those awesome FMQers didn't learn it overnight. Many have been doing it for over 20 years, so don't be overly critical of yourself. You'll see improvement with every project you complete.
Jan 18, 2018 | Necchi Sewing Machines
Brother CS-8060 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
