Question about Samsung HLR5067WX 50" Rear Projection HDTV
The Dlp bulb
There is no picture.
The Dlp bulb is arcing inside about every 30 seconds and make a loud arcing sound
  • Samsung Master
  • 8,617 Answers
The bulb may be defective or it may be the ballast. The bulp is alot cheaper, try replacing the bulb first.
Posted on Aug 31, 2008
Replace bulb
There are two possibilities. A burst out capacitor can make a loud pop sound. The second one is with bulb. Check both of these. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 975 posts to different brand TVs now.
Oct 11, 2012 | Samsung DLP HL-P5663W 56" TV
Wd-y65 dlp, have sound, no picture, tv shuts down after about 30 seconds. tryed tv reset 3 times,did nothing
sounds like you need a new bulb, mine is doing the same and the lamp light is coming on.
Nov 01, 2010 | Mitsubishi WD-Y65 65" HDTV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
My Toshiba 65HM167 orignal bulb went out after 19 months of use.The inside of the bulb exploded.I replaced with an aftermarket bulb.The tv came on for about 10 minutes and the new bulb also exploded on the...
I have the same problem. This is the second bulb in 6 months. The first one lasted 13 months. The bulb explodes inside and makes a loud snap noise, like an arc. The repair guy said it was the ballast along with the bulb. Good luck
Mar 21, 2009 | Toshiba 65HM167 65" Projection Television
3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
Dec 27, 2008 | Samsung Televison & Video
Shuts off after 30 seconds of Play
is the set still under warranty,if so call for service if not when you turn it on try to listen near the side of the unit for a fan noise or high voltage arc sound and do you see light on the screen or in the rear of set.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Arcing inside no picture
Most times arcing like this is from the Horiz. output transformer (flyback). The insulation has a break down and up to 30 KV will find the nearest path to ground. This would require a tech. to repair the unit. This repair will most likely cost around 250.00.
May 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
78 people viewed this question
Henry  Thomas
Henry Thomas
