Question about Toshiba Satellite A65-S126 Notebook
Completely black screen
When I try to turn on my laptop, the blue power light comes on and the fan runs but I get a completely black screen and nothing else. Can you help?
  • Roberta Smith
    Roberta Smith May 11, 2010
    try toggling the key that looks like a little monitor on the keyboard in the off chance you switched off your monitor... it happens.
I had the same problem before. I think Toshiba had a problem, because when I removed the battery and switched it on again it was working.
After that you can put the battery again.
Try that.
Posted on Oct 07, 2008
Hi! Having some trouble with a friends laptop here. I have it on AC power and the battery is now charged (middle light has changed from amber to blue). So when I push the power button, the top light...
Try unplugging AC power lead and then take out the laptops battery, plug the AC power lead back in and try turning it on, see what happens. If the laptop turns on then there is a problem with the battery.
Good luck and let me know how you get on.
Jan 29, 2013 | Computers & Internet
Black Screen
It sounds as if the lamp has failed possibly due to a failed cooling fan (the fan should be the first thing to come on). here are the links to the user manual if you need it; and It may be worth trying to uninstall and reinstall the lamp, but usually these fail internally rather than having bad connections etc. It is often obvious when the lamp has gone from a visual inspection. If the lamp has failed, when you replace it, make sure the fan comes on - if not then turn off instantly and investigate further. One other possibility before buying a new lamp, is that the lamp compartment cover may not be properly fitted. This will interrupt the power, so I am assuming there is a microswitch or similar that the cover or the screws that hold it should contact. Possibility is that the cover is badly fitted, or a small piece of the cover has broken, which would normally contact the switch, or the switch is faulty - if you can see the switch then a continuity meter will easily test the switch. Also check that the lamp unit securing screws are properly tightened, they also may stop the TV powering on. Please ask again if you need more help with this, if you are unsure then a photo of the inside of the lamp compartment and the lamp itself may help :)
Jun 26, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I turned my HP Pavilion 9000 series off last night and this morning I woke up to find all the lights on, the screen black and the indicator for the wireless internet showing orange instead of blue (it had...
Unplug the unit, and remove the battery. This will shut the machine off completely. You do not need to let the battery die out. Then power the unit on again. If the issue is gone, consider turning off hibernation ( power options inside control panel)
Sep 01, 2009 | HP Pavilion dv9000z Notebook
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Blank/Black Laptop screen on HP DV-6000 notebook
Please have a look at this article and consider updating the BIOS: click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 03, 2009 | HP Pavilion dv6000t Notebook
Toshiba satellite a215-s7422 laptop wil not turn on
It sounds like the motherboard is bad. There is no power being sent to the fan and that means that somewhere in the the mother board is not sending the info.
Jan 31, 2009 | Toshiba Satellite A215-S7422 Notebook
Gateway laptop mx6448
Try booting from dvd drive with rescue disk
Jul 10, 2008 | Compaq Presario M2000 Notebook
Toshiba laptop will not turn on, screen is completely black
Don't pay attention to your uncle. I had the same problem. Blue ring, power lights on. Sometimes the laptop would come up after a few minutes and then would freeze. It is a power problem. The AC jack may be broken and, most likely, you need to get the MAX1632A power controller (a 40-48 pin black IC next to the AC jack) resoldered too (get someone qualified to do it, with the right soldering station for surface mount work). Look for a complete answer at
Comment #202, by Jerry.
I followed his instructions and got my laptop back from the dead
Jun 01, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite A65-S126 Notebook Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
