Question about NetGear WGR614 Wireless Router
Connectivity today i can't connect to the internet -- i called Road Runner and they tested; all is fine. i can connect directly.  but when i go through my wireless router, i cannot connect.  any advice?
    Problem Solver:
  • 12 Answers
If you are able to connect directly that means everything is fine with your ISP, there is something wrong with router settings.
Most of the case we can resolve by rebooting the router and computer ( a complete power cycle ).
OR
Once you try to connect wirelessly, first check the ip address
how to check the ip address:
1: Click on start
2: Go to run & type cmd then enter
3: Then type ipconfig, then hit enter.
Now check the ip address.
Most of the time we get ip address start with 192**. if you are getting the ip address start with 192 it means router is providing the connectivity. Then you need to check with computer with wireless settings & please make sure that wireless switch on turnon on your computer. You will find that button on edge of the laptop near by the spearker ports & you may try move that button to right or left. That will trun on & trun off your wireless network.
Otherwise last option would be for you may contact the router company/internet service provider to re-configure the router settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
Need help, router will not connect. The internet service road runner is working when I plug directly in computer but through the router it won't activate. This router has been working for over a year now...
Try unplugging the power from Road Runner modem and disconnect the computer or router. Then only plug in the power to the router and plug in the power to the modem.
If this does not work, try resetting the modem's config to factory defaults by sticking a paperclip end into the reset button hole in the back while powering it up. hold the buttin in for atleast 15 seconds while the router restarts. then retry the first suggestion.
Jun 01, 2010 | Linksys Wireless-G WRT54G Router
My laptop will connect to my High Speed road runner internet connection but then it says I have no internet access
Contact the Internet Service Provider (ISP) or the Administrator. There might be need to set some parameters on the laptop to enable Excellent connection.
Good luck.
Dec 31, 2009 | Acer TravelMate 7100TE (9142A0194F) PC...
I have a cable modem and my connection is weak even though we have road runner. and my intyernet keeps disconnecting.
Call Road Runner and have then put new ends on your cable and run a test on the signal you get from them.
Nov 02, 2009 | Microsoft Windows XP Home Edition
HP pavilion(a220n) no connect to internet
Use the setup wizard in the internet optins and be sure that the box at the bottom of the LAN settings is UNCHECKED.
Nov 05, 2008 | HP Pavilion a1220n (A1220NED904AA) PC...
I have roadrunner internet and when i connect it directly to the main desktop computer it works fine but when i put it through a linksys router the internert doe snot work and the rest of the computers in...
You need first to configure the linksys router to work with your road runner cable internet, if you have the setup CD for the router you can use to configure the router but if not you need to manually configure the router to work with Road runner cable internet by accessing the router setup page, if you're not aware on how to manually configure the router to work with road runner you can call this number so a Tech can walk you through with the process 1-877-787-8749...
Oct 16, 2008 | Computers & Internet
Ipod touch and road runner
try to reset the Network from ipod
choose Settings > General > Reset > Reset Network Settings.
Damn sure it fix trust me
May 04, 2008 | Apple iPod touch
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Not working on my 2nd computer
I am going to assume Vista is the first OS and both machines are windows computers and you are accessing the cable service through a DI-524 wireless router. There are many issues that can relate to your problem. First does your cable provider require you to logon to access the internet. If so, try using each computer individually (with the other one logged off and shutdown) with the existing wireless connection. If this works both machines are configured correctly for the router and the issue appears to be dealing with the logon possibly having it performed by the router if possible. Second if that does not work -- on each machine bring up a command prompt window (Start > All Programs > Accessories > Command Prompt) and type ipconfig and press enter. There may be multiple local area connections but look for one with a 192.168.?.? address on each machine. The first question mark should be the same on both machines and the second different. If this works both machines have connected to the router and we are seeking another issue. If this is not true one machine has a configuration problem and cannot access the wireless router (probably the Windows ZP computer from you description). We will need to diagnose further once you answer the above questions.
Dec 05, 2007 | D-Link AirPlus DI-524 Wireless Router
NetGear WGR614 Wireless Router Logo
48 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
